Wheel Spacer nut striped.
Old Nov 28, 2010 | 10:33 PM
w4kj4k's Avatar
Angry Wheel Spacer nut striped.
I swear, the nuts that come with the ichiba spacers are made out of plastic or something, they strip SOOO easily!
But anyways guys, i've striped 2 nuts already and i was doing a search and...
http://www.sears.com/shc/s/p_10153_1...2166000P?mv=rr
Seems to be really popular and works too.
It says it work with sockets, but i was reading a review and someone said it didnt work with a socket wrench.
Does anyone have this set or used it with a socket wrench? Would you recommend it? Thanks
Old Nov 28, 2010 | 10:44 PM
thescreensavers's Avatar
Mr.202?
How bit are the nuts on the ichiba spacers? Stock are like 21mm or 23mm, I forgot.
Old Nov 28, 2010 | 10:46 PM
w4kj4k's Avatar
the spacer nuts are 17 mm, which they have that in sears kit. But im looking at the picture and... im curious how its used
Old Nov 28, 2010 | 10:50 PM
w4kj4k's Avatar
Ohh i see how it works now. You put the piece on to the nut, then a socket over it. Only thing that worries me is that the space on the spacer is pretty tight, so would this even work..
Old Nov 28, 2010 | 11:57 PM
Frankieg35's Avatar
Whenever I get spacers I'm prolly just gonna replace the nuts with ones of better quality..
Old Nov 29, 2010 | 12:04 AM
w4kj4k's Avatar
Yeh im really suprised by how easily these strip. It literally sometimes feel like plastic lol
Old Nov 29, 2010 | 12:25 AM
xXHotelCrazyXx's Avatar
Did you use a torque wrench or impact gun to install them?
Old Nov 29, 2010 | 12:26 AM
w4kj4k's Avatar
I only use the torque wrench to get it to 80. The other 4 lugs came off easily with my breaker bar... then bam this one wasnt perfectly shaped and it started stripping :[
Old Nov 29, 2010 | 12:42 AM
The threads are stripped or the hex?
Old Nov 29, 2010 | 12:43 AM
w4kj4k's Avatar
Just the hex itself luckily
Old Nov 29, 2010 | 01:47 AM
Did you use a 12 point socket or a 6 point?
Old Nov 29, 2010 | 01:50 AM
w4kj4k's Avatar
6 point, it fitted in, but then like the nut itself started to deform and stuff and i couldnt get the socket in all the way.
Its actually not FULLY striped because i stopped but yeh. I'm going to go ahead and go to sears and by that socket set and hopefully it works.
Old Nov 29, 2010 | 01:57 AM
Gdriver90's Avatar
common issues, best ones ive gound are project kics. Spendy yes, but its what hold you wheels on the car
Old Nov 29, 2010 | 02:13 AM
w4kj4k's Avatar
for sure. but going to home depot or whatever and finding a high grade nut should be good huh?
Old Nov 29, 2010 | 03:53 AM
4DGS's Avatar
You sure you have ichibas? All 10 sets of ichiba V2s I have had use a 19mm...
I have also never had any one of them strip.
