XiN
Supersonic... Hypertonic
close
- Join DateFeb 2010
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(17)
- My RideItasha Coupe
Liked:430 Times in 278 Posts
Yes, I have both front and rear SPC arms. As well as the shim kit for the front SPC and toe bolts for the rear.
i see.. guess ill have to get the front arms as well.. do you know how much camber your running off the top of your head?...Also .. Statik a vendor here sells the V1 spacers up to a 20mm... do you recommend those over the 15mm V1?
XiN
close
- Join DateFeb 2010
- LocationHouston
My camber is -1.2 all around.
And I cannot answer your question because I don't have the answer to it. I haven't done any more research after I sold my 15mm V2 spacers.
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
I think -5 is a nice setup.. especially for a daily driver..
ONLY WAy A WORK o-DISC WILL FIT IS WITH a spacer. THat will clear EVER POINT OF THE bbk OTHERWISE SOME POINT WILL HIT THE RIM. TO Make sure A TEST FIT WILL Have to be done. It may LOOK LIKE U Have enough room with ya STOCK BRake but the BBk is much larger
XiN
close
- Join DateFeb 2010
- LocationHouston
^^ That only applies to the front though. O-Disc will clear a BBK in the rear.
^ CORRECT only APPLIES TO THE front brakes. THE REAr will fit ANY BRake.. I have O-disc 11/285/20 IN THE REar.. and O-dics in the front AND TRIED already.. IF NOT THE SPacer it wont work AT all
Silencer_0
close
- Join DateDec 2008
- LocationCorona, SoCal
iTrader Feedback Score(25)
Liked:264 Times in 147 Posts
Quote:
I think it'll clear most BBK's, but not all. I have A-disc in the rear and my BBK clears literally by 1mm. I've never tried putting an O-disc on, but I'm pretty sure it'll hit.Originally Posted by konxeptionz
Frankieg35
close
- Join DateOct 2006
Depends what bbk u have also.. Some are thinner than others..
GeeGirl82
close
- Join DateJul 2009
- LocationRight Coast
iTrader Feedback Score(18)
Liked:28 Times in 27 Posts
I just bought 37 wheels for my 35 winter setup. I haven't put them on yet but I am guessing I'm going to need spacers to be at least, semiflush. Can someone help me out with what the offset would be for G37 stockers on a G35? Thnx!
XiN
close
- Join DateFeb 2010
- LocationHouston
Quote:
Yea good point. I completely looked over that. I just keep referencing Akebonos and I'm not considering the larger caliper BBK's.Originally Posted by Silencer_0
Silencer_0
close
- Join DateDec 2008
^ Have you tried fitting an O-disc over Akebonos yet? They look like pretty fat calipers haha.
Frankieg35
close
- Join DateOct 2006
Yeah I was wondering how akebonos fit over o disk.. I'm at +11 o disk in the front and was wondering how they would fit.. I'm hunting down g37s to test fit.. lol
XiN
close
- Join DateFeb 2010
- LocationHouston
Quote:
Haha, one of these days I'll do a test fit on my friend Kevin's car. He's got an 06 with candy red bonos.Originally Posted by Silencer_0
