kinetix front control arms squeaking..
most noticeable in the morning, sound like it's from bushings....is there someting i can spray/apply to lessen sqeaking without damaging the bushings? They seem to fit in there quite snugly.......
04 6mt Sedan / stock airbox mod / z-tube / k&n panel filter / crank pulley / 18" r/h c2s / s-tein springs
Re: kinetix front control arms squeaking..
I always use lithium grease inside and out of the bushings.
You'll need to remove the arm to grease it right.
You can also use WD40, but it'll wear off a lot quicker
and possibly loosen your bolt if you don't spray carefully.
2004 G35C 6MT Brilliant Silver
rezendvous420
May 31, 2020 01:26 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
