19x 11 ?
#48
#50
#51
I like my 19x10 and 19x11 combo. Pair it with good wide tires with a little help from the sway bars and you get gobbs of grip.
So are you looking at running a smaller diameter wheel up front ala NSX style? That would be interesting to do a 18x10 front with a 19x11 rear I suppose, but I still dont see the point.
Best of luck anyhow!
#53
#54
If referring to me....nope. Other way around. Larger diameter in the front. I have step lip fronts and reverse lip rears. With a step lip wheel the face is about 1" - 1.5" smaller. With the same sized diameter wheel, the rear wheel looks bigger due to a larger face. Go a size down the faces match better. It's an illusion but most people don't see past that. My front lips with step are 5" and my rear reverse lip is 5.7" but that .7" lip size difference looks more like a 2" difference. The step tricks people as does the diameter of the wheel.
