Just ordered my vs-xx's in burning black
Old Mar 8, 2011 | 02:01 PM
ptd23's Avatar
I just ordered my vs-xx's yesterday, and i went with 20x9.5 +0 and 20x11 +6 both O-disc. Im lowered on
Stance Gr+. I know i have to get my fenders rolled flat but does anyone know what camber specs i might be looking at?
Old Mar 8, 2011 | 02:40 PM
TofuProductions's Avatar
Shane- where are you on this one?
Better post pictures otherwise you'll have to ship those wheels to me!
Yaknowwhatimsayinyoya?
Old Mar 8, 2011 | 02:57 PM
Deezflip's Avatar
It depends on how low and what size tires you're running.
This guy here is at 2.2, so I'm guessing you might be at 2.5-2.7, that's just a wild guess.
Originally Posted by mt7rabbit
I would suggest tire sizes 255/30/20 for the front since this is just .02% difference from the OEM 19" diameter. 285/30/20 for the rear is also .2% diameter difference, this means that your speedometer will be very close to OEM specs.
If you decide to go with these tire sizes the front will be almost flush with a 9.5" rim and the rear will be stretched by 10 mm on each side. If you aren't looking for an aggressive setup then go with a (+18 offset all around or close) your camber will be around -1.7 for the front and -1.8 for the rear with your current drop. If you lower your car more you will need a greater camber than 2 degrees to not rub with those tires. Unless you flare your fenders or use narrower tires.
20 x 9.5 +18 with tires 255/30/20
20 x 11 +18 with tires 285/30/20
I would play around on this website to help you determine your offsets.
http://www.wheelsmaster.com/rt_specs.jsp
I run 20x9.5 +15 w/ 255/30/20 camber of -2.2 and 20x11 +15 w/ 285/30/20 camber of -2.1. I'm also dropped lower than you on Stance coils so your camber should be less aggressive. I hope that helps.
Old Mar 8, 2011 | 03:33 PM
ptd23's Avatar
I'm Pretty low right now. And I'm thinking about running 235/30/20 and 255/30/20
Old Mar 8, 2011 | 08:47 PM
DogStar's Avatar
All manner of creatures will die if you don't post up pics once you get them on. Excellent buy sir.
Curious tho why you didn't try to buy the ones D&G35 had for sale though his might have been 19"s can't recall.
Old Mar 8, 2011 | 09:11 PM
HXS's Avatar
HXS
congrats on the new set of stockers! uh... i mean rims!
anyways, unless your roads are smooth, i wouldn't go with 235/30 and 255/30.
Old Mar 8, 2011 | 09:17 PM
ptd23's Avatar
your gonna have to wait 4-6 months for pics lol... but i talked to d&g35 and i think they were 19's too.
Old Mar 8, 2011 | 09:19 PM
ptd23's Avatar
hahaha thanks.
what do you suggest i run?btw the roads are ok in my city but its a different story when i drive about an hour out.
Old Mar 8, 2011 | 09:24 PM
HXS's Avatar
HXS
245/30 and 265/30 or 275/30.
i'd do 275/30 since you're on a 11 and i'd HATE to get a bend on my rim.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
