Funky tire combination
Are your wheels staggered? Maybe your rear wheels are mounted in the front. Vice versa. It's possible. I had a buddy who had this happen to him at a dealership!
*Edit: I totally misread his original post :\ OP you are fine. As stated below, those are the stock sizes for the OEM 19s.
The wider the tire, the taller it sits regardless of the of its rating. Ex: a 245x35 sits slightly taller then a 225x35. Normally with more aggressive staggers the size difference is required so the diameter of all the tires are close.
On OEM setups this isn't required so I don't know why your car has those sizes.
Aspect ratio's won't necessarily be the same from front/back. The width and height work together to create the tire's overall diameter. Seems a tad shorter than normal for the rear of the car though.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
