sedan rim help!!!!******
Old Nov 18, 2004 | 03:11 AM
nuttyprof's Avatar
getting 18s!!
but i dont know what width to get.
-can 8.5 fit in the front? if so, what offset should i go for (im lowered btw).
-and should i go staggered or do 8.5 in the rear as well?
-and finally, what is max tire size to fit on 18x8.5(assuming i can fit those in front).
check this out guys:
http://www.spyeng.com/product_info.php?products_id=1865
let me know what you think!!!!!
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
Old Nov 18, 2004 | 11:31 AM
mark5's Avatar
Re: sedan rim help!!!!******
I've seen a lot of people here with 18x8 in the front and 18x9 in the back. No lip on the rims?
Old Nov 18, 2004 | 12:25 PM
jstwong's Avatar
I'm running 18x8.5 w/ a 40mm offset with 245/40R18's at both my front and rear. To me, that is a perfect offset [flush with outside of fender]. That setup had zero rubbing issues with the stock sports suspension.
Since then I've lowered the car 1" in the front and 0.75" in the rear [even wheel well gap now, HKS Hipermax LS coilovers]. I still have zero rubbing issues, but I was told by the installer that I wouldn't be able to drop much further [maybe another 0.25" before I started to run into some rubbing issues [non-rolled fenders].
As a side note, my current wheel set up is about 0.5" smaller in diameter versus the stock 17" wheel with the Goodyear GSD's.
Old Nov 18, 2004 | 01:30 PM
nuttyprof's Avatar
any chance of fitting 255/40/18 on 18x8.5 without any issues with rubbing or anything else?
Old Nov 19, 2004 | 12:44 AM
G35Amistad's Avatar
255 for Rear, NO PROBLEM (^^)
Thank you.
DXC
dxc@canautoclub.com
AmistadUSA
www.AmistadUSA.com
www.CANautoclub.com
Old Nov 19, 2004 | 09:54 AM
blackonblackG's Avatar
im running 18 by 8 with 45mm offset. the offset is perfect with all 4 tires pushed out flush to the fenders. for tires i have 245/45 they are nice but next time im going with 245/40. my wheels/tires weigh apox. 48.5lbs and my stock 17s wheels/tires weighed about 46lbs. i belive there is a good 2.5-3lbs weight difference in a 245/45 and 245/40 tire.
Old Nov 19, 2004 | 10:52 AM
IQ9's Avatar
IQ9
The tire weight depends on the manufacturere of the tire as well so look around to see if you can find a 245/45 in the weight you want.
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHERE ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
Old Nov 19, 2004 | 02:17 PM
jaspergtr's Avatar
blackonblack - what brand of tire are you running?
that seems pretty heavy for a wheel/tire combo. if you're concerned about weight, you should go with a 18" ssr proffessor (15 lbs) or something.
Old Nov 19, 2004 | 03:16 PM
nuttyprof's Avatar
lighter rims are good and all, but they will bend easier. thats a scary thought to have your rims crack or bend while driving.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
