helpppp need wheel adapter
Old Apr 29, 2011 | 05:48 PM
sky14's Avatar
hey guys i rarely post up on this forum but i have a fx35 and i want to run rims that came off my 2007 bmw x5.
what i wanted to know is if its possible to run a wheel adapter to put the rims on.
and what type/ who makes it?
thanks
mikey
Old Apr 29, 2011 | 06:14 PM
4D05G35's Avatar
Not sure of the make, but they are out there.
BMW run a 5x120 and we have a 5x114.3.
Old Apr 29, 2011 | 07:41 PM
sky14's Avatar
Thanks bro
Old Jun 4, 2011 | 05:58 PM
sky14's Avatar
i ended up buying a set from adaptusa.
now im getting wheel shake. i hope its not cause of the adapters. im getting my tires rebalenced as my friend did them on a small machine. the rims are 22s ashantis
i also changed my tire rods as well.
does any one have any suggestions to stop the wheel shake?
Old Jun 4, 2011 | 06:02 PM
4D05G35's Avatar
Are those wheel spacers hub centric to your hub bore and to the wheel bore?
Old Jun 4, 2011 | 06:03 PM
sky14's Avatar
they are hubcentric to my hub bore
Old Jun 4, 2011 | 08:13 PM
4D05G35's Avatar
I would think that the wheels would center themself from the lugs. The biggest part I would think is the spacer being hubcentric to the hub.
Old Jun 6, 2011 | 03:12 PM
4DGS's Avatar
You need to mount the wheel properly when you seat it.
Last I checked, BMW trucks use a 72.5mm hub. The FX I am pretty sure uses average nissan 66.1mm.
Best way to do it is to put the wheels on with an impact gun and cross torque them bit by bit while shaking the wheel a little. This way the wheel can never rest on the studs causing a slight out of round vibration.
EnCr1pt3d
Jul 8, 2019 02:48 PM
willdogs
Dec 8, 2015 11:32 AM
Gip
Aug 24, 2015 05:31 PM
DRG35R
Jul 31, 2015 10:23 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
