Should i go with 10mm or 15mm spacers
Old Aug 24, 2011 | 10:39 PM
  #61
jazzy's Avatar
Fenders rolled and I think you shoulb be good
Old Aug 25, 2011 | 07:04 PM
  #62
jazzy's Avatar
Old Aug 26, 2011 | 06:26 PM
  #63
qbanboy's Avatar
the only thing you missing is the rear splash guard...... if you get it it will look more fit the back of the car the curve the fender does make it look too wide....i know that's the purpose but it will look much better with the splash guard.... just my opinion....looks great the way it is would look better with that small detail......
Old Aug 26, 2011 | 06:28 PM
  #64
qbanboy's Avatar
also will finish the line from the side view...front bumper and side skirt are lower than the rear fender with the splash will be even.....
Old Aug 29, 2011 | 02:33 PM
  #65
Gitsum's Avatar
Did you change front tires? Are you on 225/255 now? Did you have spacers on either end on the last pic?
Old Aug 29, 2011 | 03:44 PM
  #66
CantDieLS's Avatar
wheels look great, and fitment is on point. Whats ur offset in the rear? im going tomorrow to get my fenders rolled and pulled... debating if i actually need them pulled
Old Aug 29, 2011 | 05:14 PM
  #67
jazzy's Avatar
yes fronts are 225 are rear 255 last post with the pics i have spacers all around
thanks man i am at +5 i need the fronts pulled rubbing a little bit rears are fine with the roll
Old Aug 29, 2011 | 07:11 PM
  #68
Gitsum's Avatar
Looks very nice indeed! What size spacers did you go with?
Old Aug 29, 2011 | 07:14 PM
  #69
jazzy's Avatar
thanks fronts are 25mm and rears 10mm
Old Sep 6, 2011 | 01:27 PM
  #70
CantDieLS's Avatar
ok so im wondering if the guy who i spoke with f*cked me... my rears are 20x11 with +35mm offset. Im having trouble fitting them lol, im going to have to raise my car but from what has been explained to me and from my understanding of offsets, isnt the lower the offset the more aggressive? meaning ur +15 offset should be poking out more then my +35??? and adding a 10mm spacer to 15mm offset should make it +25mm??? or do i just have it totally backwards and i got boned?
Old Oct 15, 2011 | 10:20 PM
  #71
Inspired's Avatar
did you go with 225 35 or 225 30? and for the rear i'm guessing its 255 35?
Old Oct 15, 2011 | 10:49 PM
  #72
jazzy's Avatar
225/35 & 255/35
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
