Can I move these rear tires to front?
Old May 22, 2011 | 12:23 AM
TheloniousMonk's Avatar
I just bought a G35 from a private seller. He just got new tires put on the back before he sold it to me. The car already has the stock 19" rims.
I want to buy new rims (19s) and tires, but I think it would be a waste to get rid of the back tires which are are 255/40/19.
My questions:
Can I move the rear tires to the front? Or would they be too big?
I plan to get wider tires for the back and I want to lower the ride about an inch.
Sorry. I am new to all this.
Old May 22, 2011 | 12:30 AM
G35SedanGrn's Avatar
255's should be okay on a 8.5-9.5inch rim so go 9.5 +15 and 10.5 rear +15 and it should look clean
Old May 22, 2011 | 12:41 AM
Awesome thanks. I'm guess 8.5-9.5 is the width? What is the +15? (Sorry I'm a n000b)
offset, 9.5 +15 and 10.5 +15 is going to sit really flush. (some may tell me that +15 isn't that flush lol cause some people on here are way to flush for my taste) I'm also not a offset pro like some guys on here.
Old May 22, 2011 | 12:48 AM
For the tires on the rear, can I get 275/35 or will the aspect ratio have to be the same as the front (275/40)?
I saw some people on here with 275/35/19s and it looked awesome.
Old May 22, 2011 | 12:50 AM
well I'd get 275/35 if i was really low, like 2+ inches lower than stock at the very least...I'm running 225/40/18 and 245/40/18 on 18x8 +30 on my sedan and I'm lowered an inch all around & think I'm going to get 45's next time around because the fender gap looks to big, also messing with ur sidewall height will throw ur speedo off a little so keep that in mind.
Old May 22, 2011 | 02:06 AM
4D05G35's Avatar
My questions:
255/40/19 are pretty big for tires the front. A 275/40/19 is way to big for your car ( over an inch taller than stock). I would sell the tires and buy a size more suitable.
You can run different aspect ratio's as long as the overall diamter is the close, or within the accetable range. 255/40/19 front and 275/35/19 rear would put your rear tire 1/2 and inch shorter than the front, which would look odd.
Old May 22, 2011 | 02:10 AM
Golden_Shower's Avatar
255/40/19 on a 9 inch rim +15 wont work for the front on a lowered car you will rub and they are the wrong size. As said above you want to keep them in the same aspec ratio since we are a real wheel drive car and you front tires will look bigger.
Old May 22, 2011 | 02:13 AM
I have a friend running 255/35/18 and 285/30/18 on his Z, his fronts don't rub & rears don't rub with his fenders rolled...I've always thought Gcoupe & Z's have the same offsets...
Old May 22, 2011 | 02:19 AM
I have 275/35/19 19X10+15 rear and I rubbed bad in the rear rolled my fenders and only rub going in the drive way. I also have a 245/35/19 19x9+15 in the front dropped 2 inches and if I go lower I will rub. You are comparing 18's and 19's with almost the same size tire.
Old May 22, 2011 | 02:24 AM
Thanks. Good info
Old May 22, 2011 | 02:28 AM
You want to keep the side wall of front and rear the same especially when running after market wheels since people will notice them. I would actually say to run a smaller tire than mine on my wheels which I will do when Im done with these tires because it would look better.
Old May 22, 2011 | 01:19 PM
4D05G35's Avatar
Those are some tiny wheels (24.7" - 25"). Are you sure those are the right sizes? In comparison those 255/40/19 are 27" tall.
You have to factor in the width and offset when figuring out if they will rub.
There was, or still is a coupe on here running 275/30/19 front and rear. He was able to because the offset was right.
Old May 23, 2011 | 12:41 PM
& yeah i'm sure thr that small. hankook Rs3's 255/35 and 285/30
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
wojowojo16
Jul 27, 2015 09:57 AM
rping
Jul 26, 2015 09:53 PM
nascarbuff17
Jul 16, 2015 10:23 AM
