20" Tire Size Question
Old Jun 18, 2011 | 01:00 PM
JuicedAthletics's Avatar
My wheels are 20x9 (+10) 20x10 (+5)
Currently my tire sizes are 255/35 front and 275/30 rear. Falken FK452
I am dropped on s-techs and rear fenders are rolled.
In the rear I am fine, no rubbing at all. In the front I rub all the time when turning or hitting small bumps. It also throws my VDC off.
I am ordering 235/35 for the fronts which I believe will solve my problem with rubbing.
In the rear, would be better to keep the 275/30 or throw on the 255/35? I have been thinking the 35 sidewall in the back might add a little more comfort.
Thoughts?
Old Jun 18, 2011 | 02:24 PM
GOAT35's Avatar
I have similar issue I have 275/35/20 on the rear of my sedan. The silver wire is showing and i'm in a hurry to change the tires. All I can find nearby is 255/35/20. I want to know if that would be ok? I have 245/30/20 in the front.
Old Jun 18, 2011 | 06:26 PM
blk35's Avatar
A 225 35/20 f and 255 35/20 are as close as you can get to stock height if you need to change the tire sizes that will work. If you dont want to run in other sizes like 225 30 r20 or 235 30 r20 245 35 r20. If this helps.
Old Jun 21, 2011 | 06:58 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Sedan or coupe?
Old Jun 22, 2011 | 06:00 PM
Its on a coupe.
Old Jun 23, 2011 | 04:46 PM
PLATINUM SPONSOR
We typically run a 245/30-20 and 275/30-20 which works out well.
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
