Offset question.
Old Jun 20, 2011 | 06:17 PM
FlopsDaCat's Avatar
Offset question.
Hello everyone.
I have two quick questions.
I am in the middle of buying a set of Replica BBS lm's from the vendor CarBodyKits.
The wheels are HyperBlack VarrsToen 19" ES 1.1.2.
He informed me that they are 19x9.5 front and 19x10.5 both with +0 offset.
My first question is would that be a good offset to go with so that I won't have to spend extra on spacers?
And my second question is what size tires should I run so I can drive comfortably and not rub?
(I do daily my G and I drive it everyday and I only want a little stretch on the tires. Not to much.)
Any and all help is greatly appreciated.
Thank you
Old Jun 20, 2011 | 06:24 PM
4DGS's Avatar
Are you lowered?
I really should help you since 1. I hate reps 2. This should be in the random question thread. 3. You should do a search and see all the other guys on varrstoens that asked the same thing
You'll need camber, fender rolling and a little stretch to fit the 0 offsets.
Old Jun 21, 2011 | 04:25 PM
BAUSauto's Avatar
We only have +0 offset in stock =( which are very very aggressive for coupe and will need negative camber and stretch tires or fender rolling.
+12 would be the perfect coupe offset but they are not instock at the momment =( ETA on them is around another 3 months.
+0 is very aggressive so you wont need a spacer at all
+12 is "flush" with the fender
+22 is very very aggressive sedan
+30 is flush for sedan
So to answer your question you'll want +12
Next question will largely depend on how LOW are you and how much negative camber you're willing to run but generally:
245/35/19 Front +12
275/35/19 Rear +12 or 275/30/19 Rear +0/+12
Run-Flats and brands such as Bridgestones have meatier sidewalls and may cause rubbing. Other brands like Toyos and Falkens have a smaller sidewall and less rubbing.
Old Jun 21, 2011 | 04:29 PM
BAUSauto's Avatar
Front: 19×9.5 +12 | 245/35/19
Rear: 19×10.5 +12 | 275/35/19
Front: 19×9.5 +12 | 225/40/19
Rear: 19×10.5 +12 | 245/40/19
Front: 19×9.5 +22 | 225/40R19 KUMHO KU31
Rear: 19×10.5 +12 | 255/40R19 KUMHO KU31
Old Jun 21, 2011 | 04:31 PM
BAUSauto's Avatar
Font: 19×9.5 +12 | 245/35/ 19
I know I'm showing you 2.2.2s but 1.1.2 will fit the same way
Old Jun 21, 2011 | 04:40 PM
4DGS's Avatar
Should probably delete the first photo Eric, He doesn't have a sedan. Will only confuse.
Old Jun 21, 2011 | 04:54 PM
BAUSauto's Avatar
^ oops good looking out thanks x.x
Just +0 is very aggressive (you wouldnt want any wider unless you want to be featured on canibeat or hellaflush)
+12 is money for coupes =)
+22 looks a little tucked in (kinda like all the volks you see)
+30 I wont sell to a coupe lol
Old Jun 21, 2011 | 07:33 PM
FlopsDaCat's Avatar
^^Thank you. You have been more then helpful
Old Jun 21, 2011 | 07:46 PM
GR6RR's Avatar
get zeros and roll the fendors!!!
or 12s and run some meaty tires! still need fendor rolled...
jmo
Old Jun 21, 2011 | 09:12 PM
BAUSauto's Avatar
+0 looks sick if done right but definitely needs a Drop and a Kit to be pulled off IMO.
or at least the OEM aero with a drop
- Eric
Old Jun 22, 2011 | 12:31 AM
Marc Bynum's Avatar
Zero offsetttttttttt! Don't be a pussyyyyyyy! =P
Old Jun 22, 2011 | 12:54 AM
Xet's Avatar
Xet
I would do +0 at least in the rear. I have +12 all around and was disappointed by the rear and ended up getting a 15mm spacer to get it more where I wanted it.
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
AT23
Sep 15, 2015 07:44 PM
