Can i fit a 315 on a 11'' Wide rim?
Old 06-21-2011, 07:51 PM
nyqueenz's Avatar
before i make the pull, i just wanted to see if anyone has done this before..
I'm looking to up my tire size in the rear right now im runnin 305/30/19 no prob on a 19x11 rim..
Will it be possible to run 315/25/19?
Old 06-21-2011, 08:06 PM
GeezNuts's Avatar
I would say that should fit some people are running 295's on 10.5 so i would say on an 11 should be able to get a 315.... now as far as if you will rub, that's a different story
Old 06-21-2011, 08:20 PM
nghiars's Avatar
it will fit on the rim but will it fit in your wheel well. As long as you have clearance for that, you'll be fine.
Old 06-21-2011, 09:39 PM
nyqueenz's Avatar
here is my wheelwell now with 305/30..
With 25 as a sidewall i wouldn't have much worry as i would with 30 what i have on the car now.. my fenders are pulled/rolled to the max..
Old 06-21-2011, 09:42 PM
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by g35man04
here was an old setup of mine....
no spacers in the rear and 15mm spacers up front..
ANNNNNDDDD
325/30/20 in the rear...YES! 325!!! fit without rubbing!
Fronts were 245/30/20
should answer your question lol that's a 10w
Old 06-21-2011, 09:45 PM
nyqueenz's Avatar
^ Thanks it does..
Old 07-10-2011, 07:42 AM
nyqueenz's Avatar
BUMP new tire set up will be..
265/30/19 front 315/25/19 rear... look for the pics to come soon..
Old 07-10-2011, 10:16 AM
WhosUrBuddiee's Avatar
Depends on your offset. Good possibiltiy you will rub. I had 305s on my 20x11 +30 Asantis and I still rubbed.
Old 07-10-2011, 01:30 PM
4DGS's Avatar
^ you had asantis?? ICK
You'll be fine man, the 315/25 is actually smaller than the 305/30 Knocking the sidewall down will make a big difference.
Old 07-10-2011, 07:54 PM
jookyshank's Avatar
I haz hugz to givez
In for pix of Spartan status tires
Old 07-10-2011, 09:15 PM
nyqueenz's Avatar
Old 07-10-2011, 09:16 PM
nyqueenz's Avatar
NITTO INVO = = )
Old 07-10-2011, 09:33 PM
4DGS's Avatar
Just wanted to let you know, your fenders are not pulled to the max. I could definitely pull more out of those and that before it starts looking retarded.
Old 07-10-2011, 09:47 PM
nyqueenz's Avatar
With the 305/30 sidewalls on the rears and my set up right now.. i have no rubbing at all.. I dont see a need to pull the fenders out anymore..
Old 07-10-2011, 09:50 PM
4DGS's Avatar
I know, I was just referring to this.
Quick Reply: Can i fit a 315 on a 11'' Wide rim?
