Frustrated new member
Old Jul 14, 2011 | 06:54 AM
  #46
jwrape's Avatar
Originally Posted by noles4423
Would you consider stock flush or sunk in? Example, would a set of 20 8.5/9.5 38mm wheels sit more flush or close to a stock wheel setup (kind of sunk in a bit)? no spacers.
My worries were purchasing a set of wheels that may stick out too far then not being able to adjust. AAh, the joys of being a newb!
I have 19x8 and 19x9.5 with a 38mm offset on them. They came with the car when I bought it. They used to sit in like this.
I wanted a more flush look for it because it looked funny to me.
I added 25mm spacers on all four corners to bring my offset down to 13mm.
Now it looks better.
I would still like a little less offset, maybe another 10mm but I don't feel like paying for new spacers.
Oh, but on the rear I had to roll the fenders just a little to fit 275/35/19's on it. If I didn't want to roll the fenders I could have run a 255/35/19 on the rear but the tire would be rounded off more. I like the low and wide look of the 275's
Old Jul 14, 2011 | 06:56 AM
  #47
noles4423's Avatar
Originally Posted by jwrape
Agreed, I always can't stand the way some people will put on wheels and it looks like the car will roll over on a sharp turn cause the wheels are so far under the car.
For example: Not enough positive offset. Looks cheesy.
Funny thing is, he thinks he's cool in his Purple Widebody Supra. If you go wide body, you have to have the wide tires to fill it out.
Woooah! Thats not what I meant! That looks awful. What offset would produce that look?
Old Jul 14, 2011 | 07:00 AM
  #48
jwrape's Avatar
LMAO!
That's a Supra and he added a Widebody kit and them left, probably, his stock size 35mm offset wheels on when he should have mounted a MUCH wider wheel cobination with a low offset to fit them into the fenders.
No telling exactly what his offset is without measuring BUT it's definately a good example of bad offset choice
Old Jul 14, 2011 | 07:03 AM
  #49
noles4423's Avatar
I was about to purchase a set of 20's with a 38 mm offset 20 8.5/ 9.5. I guess spacers will be if I do. Thanks for the pics. I really see the difference.
Old Jul 14, 2011 | 07:09 AM
  #50
jwrape's Avatar
Yea, I bought these off Ebay
Once again, sorry to those who hate Ebay.
These have been great for over 35k miles this past year. Never have had any issues with them. They wer $69/ pair on Ebay.
I still check the lugs every now and then to make sure they are tight but they have never moved and they came with a Hubcentric ring as well.
Here is my fender before I rolled it a little in the rear. The fronts fit perfectly.
Old Jul 14, 2011 | 09:54 AM
  #51
noles4423's Avatar
Man, that supra looked bad. Well, I'm favoring the 20's. I'll buy them and start from there. The offset is 38mm all the way around. I'll just look to grab some spacers too. Your car looks good by the way.
Old Jul 14, 2011 | 09:58 AM
  #52
jwrape's Avatar
Sounds good to me. I wanted 20's, especially cause I tend to find cheaper tires for 20's instead of 19's due to the popularity of the sizes.
Maybe one day I will switch out wheels if the opportunity comes up.
My wheels are ok, but I really want something around 10"-10.5" wide to fill the fender inside and out. But those are expensive as you know. :-)
Thanks for the compliment. Good luck with the wheels, post a pic when you get them.
KruZZe
Feb 27, 2023 05:04 PM
AL8782
Oct 3, 2015 10:26 AM
