What are X guys running for offsets
Old Jul 13, 2011 | 02:56 PM
ANMVQ's Avatar
Hey what are the X guys running for staggered wheels. Offsets
I'm trying to find a set of rims I like but the ones I like are 19x8.5 +35 and 19x9.5+40, 245/40/19 an 275/35/19 tires? thanx for any info you have, Wheels are a weak spot for me.. All the offsets confuse me. :/
For my X coupe. Sorry guys,
Old Jul 13, 2011 | 03:09 PM
iiiiiekoiiiii's Avatar
19x9.5 +3 19x10.5 +17
Old Jul 13, 2011 | 03:20 PM
4DGS's Avatar
^ that was an incredibly unhelpful post....
19x8.5 +35 and 19x9.5+40 are pretty common offsets for the sedans and you wouldn't have a problem running those.
However a spacer up front and being lowered would definitely be good.
Old Jul 13, 2011 | 03:22 PM
ANMVQ's Avatar
Ok will these be flush or should I be using spacers, I have 20 MM on the car now, Sorry this is for my Coupe not the sedan. thank you.
Old Jul 13, 2011 | 03:24 PM
4DGS's Avatar
You really should have mentioned that.
Those wheels will fit like **** then lol
Go for a wider stagger do like a 9/10 stagger and aim for the offsets to be around +20
Old Jul 13, 2011 | 03:27 PM
I know and it was ment to be cause his post was the same way lol
Old Jul 13, 2011 | 03:34 PM
ANMVQ's Avatar
ok thanx Just changed the first post also, Sorry about that.. So 9 front 10 rear but them what is all this about the overal diam for the AWD system???
Old Jul 13, 2011 | 03:43 PM
offsets have nothing to do with ur awd. Thats like letting your hair grow to be smarter...
Its all about the tires you're running. If you will not be stretching tires. You'll be good with 245/35 275/30
Old Jul 13, 2011 | 03:47 PM
4DGS's Avatar
http://www.1010tires.com/tiresizecalculator.asp
use that, enter the tire sizes and then hit enter, at the bottom it will show you a difference in size in a percentage. Keep that percentage under 3% and as close to zero as possible.
ANMVQ's Avatar
laughed at the hair grow comment.
Ok so the tires are good 245-40-19- - 275-35-19. Just look for something with lower offests, Like 20-25? Should that be both wheels.. I can get all four in 19x9.5 but with 20 or 25 offsets?
Old Jul 13, 2011 | 03:51 PM
ANMVQ's Avatar
Cool thanx, Show a .53% change so like a half percent is ok, Thanx man
Old Jul 13, 2011 | 03:55 PM
if ur going on 19s yea 40/35 profile are fine
If you go 9.5 all around 20-25offset will be fine. Not crazy flush but decent.
figured hairgrowin was the best example lol.
Old Jul 13, 2011 | 04:24 PM
ANMVQ's Avatar
I have the stock 18 sport wheels on the car now with 20MM spacers. Wish I knew the offset of the stock 18 sport wheels or are the same as the 19 sport wheels+43 front +45 rears?
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Soumilg
Jul 18, 2015 12:33 PM
