everybody with TEIN FLEX
Old Dec 11, 2004 | 03:44 PM
severedties's Avatar
hey after u guys installed your flex coilovers was ur suspension real noisy? like clanking noise. i heard from a lot of people that it is just the coilovers breaking in...can anybody atest to this? if it happend to you guys how long did it take to stop?
Old Dec 11, 2004 | 04:36 PM
coolie's Avatar
mine was and still is. i took it in to get it tightened once, and that helped for awhile. but it started up again.
i'm going to take it in again. it just sounds "clanky" on very bad bumps.
it is very stiff though, so the body might squeak as well.
Shaun
Old Dec 11, 2004 | 08:08 PM
it sounds like it is only on the rear passenger side, and it is definitly not the body....im gunna pull it all out and check it out again....
Old Dec 11, 2004 | 09:49 PM
THX723's Avatar
G Kreuzer
You should not have that noise ... unless you have the 1st gen Type Flex.
Check the center nut (from the top) ... they may and are often loose.
Old Dec 12, 2004 | 11:51 PM
Profile4's Avatar
yes yes yes! finally someone else has the same exact noise i have! rear passenger side always clunks over bumps. its very bumpy in NY, so i attributed something getting loose in the suspension. both the suspension and parcel shelf were making annoying noises, so i took the car in to the dealer and they fixed the parcel shelf for a bit, but after a few bumpy roads, noises came back. plus the shock noise never got fixed. i thought maybe the shock itself was loose, so i raised the car but the shock was in pretty good. i will try to tighten the center nut in the future, but i have the edfc and can u just take that thing off and put it back on without problems?
i hope we can fix this problem cos its annoying the crap outta me!
Old Dec 13, 2004 | 02:51 AM
wickedik's Avatar
let us know if that fixes it. im about to sell mine and go with the cs because of these noises. well that and the stifness..
Old Dec 13, 2004 | 11:08 PM
roko's Avatar
Unhappy suspension
I don't have the Tein Flex but I have a clanking noise. I have theTein CS and when I hit any bumps it clanks.Sounds like my whole front end is loose. Took it in today,they almost took it all apart and re-tighted everything(4hrs) but still clanks any thoughts???????????
Old Dec 14, 2004 | 12:47 AM
Sukairain's Avatar
roko, how do the CS ride and handle? I am trying to decide between the Flex and CS. I don't think I ever need 1/2 the stiffness setting on the Flex. On the hardest setting, does the CS offer enough performance benefit to justify its price? Do you notice an improvement in the handling of the vehicle as well as comfort?
Old Dec 14, 2004 | 09:41 AM
roko's Avatar
Sukairian,the ride is much better than stock, and much softer than the Flex.
By the way Thx 723 thanks for the tip, will try the center nut this week and see if that works.
Old Dec 15, 2004 | 12:45 AM
Riffster's Avatar
I occasionally will hear a clunking from the coilovers - usually while descending a parking garage ramp I frequent near work and more rarely on hard bumps.
I have had the coilovers now for nine months so I would guess they are broken in - especially since I do put quite a few miles on the coupe.
- Riff
Old Dec 15, 2004 | 12:56 AM
THX723's Avatar
G Kreuzer
Be wary that the noise is not from the 'Rear Axel TSB', which can usually only be heard when at very low speed as you've described.
In contrast, if parts of the coilover were not bolted down tightly or correctly, the noise will grow more obvious when going over bumps and irregularities as speed increases.
Personally, I have the rear axel issues so I hear the ticking/crunchy/clunky sound when backing out of the drive way. I just haven't the time to have it serviced ... that'll be my new years resolution
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
nissandrifter32
Dec 22, 2015 04:28 PM
bigmike
Sep 17, 2015 01:58 PM
