Bad bearing caused my 2 peice rim to come apart???
Old Aug 24, 2011 | 10:16 PM
G35 Dream's Avatar
My front passenger rims' allen bolts that hold the center to the barrel came loose. Im just wondering if my bearing that is going out might have caused enough vibration to loosen them. Im going to have the wheel hub bearing replaced in the morning and I already put them back together (used lock tight) but cant get ahold of any tourqe specs. They are the Ro_ja r2-5 same as the Volk GTC barrel with Gram Lights center.
Old Aug 25, 2011 | 12:23 AM
4DGS's Avatar
No, that's an assembly error.
They need to be torqued all the way around at 15-20 ft/lbs then again 30-40ft/lbs.
rezendvous420
May 31, 2020 01:26 PM
ScraggleRock
Aug 11, 2015 10:16 PM
atk08
Jul 30, 2015 03:12 PM
itschuckster
Jul 25, 2015 08:07 AM
