Tires size question
Tires size question
I know there is a million questions on this...
i have a coupe with the ray wheels, I just put 245/40/19 on the rear, my front has 225/40/19 from the past ower I want to change the front but unsure what I should be putting there.. is it
245/35/19 or 235/40/19 I am unsure what number I change to make the setup correct. I did find that a popular size was 245/35/19 on front and 255/40/19 but I couldn't get 245/40 when I was buying them.
Dubi, you should have asked if he is lowered or plans to.
OP, you plan to lower the car or are you lowered now?
If you put a 245/35 on a stock height car it's going to look tiny and retarded.
if you're stock height, then go with the 235/40.
