Any performance issues with spacers?
^^Unless you buy the **** Ichiba crap and strip the nuts with about 10ft/lbs of force because they are as soft as wax. I swear to God I will never spend another dime on anything that comes from that company. I've had 4 of their products and they have all failed in some way.
If you're going to use spacers don't settle for anything less than the best quality. Buy them from our MARKETPLACE under vendor suspension. Stay away from eBay trash where you'll only have nightmarish issues! Spacers do put unwanted pressure on your wheel bearing, which aren't the most reliable to begin with. I dislike spacers and if you discuss them with any good alignment mechanic they tell you to pass on em. Do what you want but for the safety factor buy the best quality....you life may depend on it!!
Gary
Gary
While at it can you post examples of this " Ebay trash" failing? I would hate for you to speak without proof.. I'm interested in these " nightmareish issues" you speak of. please post examples.
BTW a 19x11 + 30 with a 20mm spacer puts the same stress on the hub as a 19x11 + 10 . Just incase you were wondering.
All for the info the the person seeking it.
I do not claim to be correct, but I am interested in your theory.
Thanks.
Can you explain the stress difference between a 19x10 + 30 wheel and a 19x10 + 15 on the wheel hub, mainly the bearing pertaining to the G35? Please post examples. Looking at your avatar pic you are NOT running wheels that simulate the factory offset and width. WEIRD that you crap on spaced out wheels and you yourself run wheels that are more agressive (in turn putting undue stress on the wheel bearings) wheels. Hmm
BTW a 19x11 + 30 puts the same stress on the hub as a 19x11 + 10 with a 20mm spacer. Just incase you were wondering.
Thanks.
Thanks.
