Tire help
Old Dec 7, 2011 | 06:10 PM
g35915's Avatar
Tire help
i got 19in rays and wanted to see if these tires wouldd work front 235/35/19 and rear 265/30/19... the brand is general exlplain uhp has anyone use this brand before ?? getting a good deal on them thnx
Old Dec 7, 2011 | 06:49 PM
gary c's Avatar
With your 19" Rays coupe wheels you could easily run 245/40s front and rear and the cost would be less than the strange size you chose. General tires?? Check out www.thetirerack.com for better quality tires and a good price. Ask them about UTQG (wear rating) that should be over 250 and under 300 for good wear and traction...knowledge is power!
Gary
Old Dec 7, 2011 | 08:48 PM
g35915's Avatar
well the tires came off a vette its from a friend they have 90% left and he wants 220 for them
Old Dec 7, 2011 | 08:59 PM
crazynuts16's Avatar
i would not run a higher profile in the front than the rears, but thats just my opinion.
good luck!
Old Dec 7, 2011 | 09:08 PM
herrschaft's Avatar
Use this: http://www.miata.net/garage/tirecalc.html. If the front & rear tires have less then a 3% difference then they will work.
Old Dec 8, 2011 | 10:37 PM
gary c's Avatar
Originally Posted by g35915
i got 19in rays and wanted to see if these tires would work front 235/35/19 and rear 265/30/19... the brand is general explain uhp has anyone use this brand before ?? getting a good deal on them thnx
These sizes may work but they wouldn't be my choice unless you can't pass up this deal due to finances.
Gary
Old Dec 9, 2011 | 03:45 AM
4D05G35's Avatar
First thing that comes to mind is that you might have a hard time with the 265/30 tire on an 8.5" rim, the width and profile doesnt make a good combo.
Secondly, unless the car is dropped a bit, it will look funny because the tires are 1.25-1.5" smaller in O.D.
I would honestly pass for those two reasons alone.
Old Dec 12, 2011 | 02:28 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yeah, those are a bit outside the norm for width and diameter.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
