Slight vibrations at higher speeds with new wheels
Old Feb 5, 2012 | 07:03 PM
acchen's Avatar
I just put on a new set of Work Schwert SC1 20x9.5 20x10.5. I made sure to put the lugs on tightly and correctly so that they're flush on the hub. There are hub rings on all 4 corners. I noticed that when I drive at higher speeds, around 70+MPH, I start feeling a slight vibration in the chassis. I am lowered on BC coils and am coming from Volk GT-M 19x9.5 19x10.5 and I had no problems with those. Could it be partially because I'm moving to 20s? I understand there are a lot of factors when it comes to vibrations, but any possible ideas come to mind?
Thanks in advance.
Alvin
Old Feb 5, 2012 | 07:59 PM
0MGHI2U's Avatar
either the wheels aren't balanced correctly or your air pressure could be low.. i drove and when my air pressure was low the car was having vibration at 70+mph. after i put more air in it didn't do it.. so here is my opinion
Old Feb 6, 2012 | 02:09 PM
VMRWheels's Avatar
I'd check the balance on the wheels. Were they Hunter Road Force balanced? Because if not I'd highly recommend finding a shop that uses Hunter equipment to rebalance them.
Old Feb 6, 2012 | 05:05 PM
GarageLife's Avatar
+1 on it being a balance issure
Old Feb 7, 2012 | 02:08 AM
acchen's Avatar
Thanks for the advice everyone, I'll see if I can rebalance the wheels!
Old Feb 7, 2012 | 11:52 AM
neal@tirerack's Avatar
PLATINUM SPONSOR
+1 on rebalance
MyfistYourFace
Aug 8, 2015 11:58 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
Soumilg
Jul 18, 2015 12:33 PM
