toe/camber adjustment
Old Feb 6, 2012 | 09:39 PM
jimmyboi860's Avatar
So my mechanic and I have ran into a problem. I just installed coilovers, spc rear ccamber kit with toe bolts, and rolled rear fenders.
Everything needed in order to fit these 20x10 rims with 275 tires in the rear.
I've talked to a couple fitment gurus on the sedan section of the forums and They've told me I would have to run -3 camber and to tell the alignment shops to zero the toe in the rear. My mechanics been trying to hand adjust the camber and toe so that I can at least drive it to a alignment shop.
The problem is he's running into is that every time he adjusts the camber so the wheel tucks under the fender (negative camber), the toe keeps pushing out. So hes saying he needs more toe adjustment...Can anyone chime in or give me some advice?
Old Feb 6, 2012 | 10:19 PM
broke_as_ajoke's Avatar
just taking a jump here, but did he adjust the toe bolt in the rear. (FYI there is a way that the toe bolt in the rear has to be installed. It's a pattern that has to be cut.). That i'm not sure but i think it might be a DYI on here somewhere about installing the rear toe bolt using a dremel tool. Someone correct me if I'm wrong.
here is a link
http://www.batit.com/forumpics/spctoeboltinstall.pdf
here is another
https://g35driver.com/forums/g35-cou...t-install.html
Old Feb 6, 2012 | 10:24 PM
JaE35's Avatar
Moderator
G35 Sedan
When he installed your spc toe bolts did he extend the washer area? Toe can't possibly be maxed out with -3 camber...i'm running -2 on stock toe bolts with toe in 0
Old Feb 6, 2012 | 10:40 PM
Yea he elongated all 4 holes properly.
@jae35 - mechanic didn't throw it on alignment machine, he eye balled it. I'm taking it to alignmen shop tomorrow for a more precise alignment, hopefully the 20x10s get tucked tomorrow and everything will b all good.
Old Feb 6, 2012 | 10:43 PM
But anymore advice, tips, help would be apprciated
Old Feb 6, 2012 | 10:52 PM
JaE35's Avatar
Moderator
G35 Sedan
offsets on your 20x10's?
Old Feb 6, 2012 | 10:53 PM
+25 I believe
Old Feb 12, 2012 | 03:15 PM
tylerxfire's Avatar
update?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
