Question about Tire Sizes
Old Mar 28, 2012 | 02:12 AM
locote665's Avatar
I own a 2004 g35 coupe and I'm putting 19 inch rims with 10.5 inch width in the back. I was wondering what the best size tire would be? I'm looking to put the biggest size tires without rolling in the fenders. I have factory suspension as well. Please help.
Old Mar 28, 2012 | 02:41 AM
herrschaft's Avatar
Are you N/A? Need to know the offset of the wheel too.
Old Mar 28, 2012 | 04:27 PM
4DGS's Avatar
285/30 is about as wide as I would go. 295 should fit depending on offset but 295s are NOT cheap tires.
Old Mar 28, 2012 | 09:43 PM
locote665's Avatar
I'm sorry idk what N/A means. Offset is 5/120. Do you think with 285/35 the tire will rub the fender with factory suspension?
Old Mar 28, 2012 | 09:48 PM
herrschaft's Avatar
N/A = naturally aspirated, meaning you don't have a turbo or supercharger. A good tire thats 285/295 is probably overkill for someone pushing close to stock power. As mentioned above, the wider you go the more expensive tires get.
Old Mar 29, 2012 | 01:18 AM
4DGS's Avatar
Uhh, think you might be mixed up, that number I'm going to guess and say is actually the bolt pattern which means these wheels won't bolt onto the G.
The offset is measured in MMs IE +25
I can't tell you if the 285/35 will rub unless I know widths and offset of the wheels.
Old Mar 29, 2012 | 03:41 PM
stelar302's Avatar
My g is all stock still exept for the tires and brakes. In back I'm running 285/35/19 on 10.5"-
With 30 offset. In front 255/35/19 on 9.5"-with 25offset
No rub whatsoever. I have pics in my album hope. That helps
Old Mar 29, 2012 | 05:07 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Best we show is 285/35-19
Jusseth
Sep 13, 2020 12:25 PM
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
