Considering Purchasing SF Challenges 19x8.5 and 19x10.5??
Old Apr 21, 2012 | 04:09 PM
daniel3ooo's Avatar
Hey guys, I'm considering purchasing a set of SF Challenges but the tire specs are 19x8.5 +21 fronts and 19x10.5 +23 rears. I was really hoping to get 19x9.5 +28 fronts.
I looked at the lip sizing chart providing my Mackin Industries and it says the 8.5 +21 has a 63mm lip whereas the 9.5 +28 has a 69mm lip. There isn't that much of a difference but would it be odd to have an 8.5 front and 10.5 rear?
Will the wheels look odd? Or should I jump on these if they are a good deal?
Old Apr 21, 2012 | 04:25 PM
g35pillow's Avatar
Personally I wouldn't do that small width on a G. And those offsets are def weak. I would look into a 9.5/10.5 setup with and better size lip then those.
Old Apr 23, 2012 | 11:14 PM
daniel3ooo's Avatar
^^ thanks for the advice..I may just continue my search but I really like those sf challenges
Anyone have pics of an 8.5 and 10.5 set up? Any negatives with going with this set up? Would this affect handling?
Old Apr 24, 2012 | 01:15 AM
4DGS's Avatar
The car will over steer a fair bit because of the thin width. But with the right size tire you might be ok.
If you're not too worried about precise handling and basically just want to throw em on as it you'll be ok.
You'll want a spacer up front for sure though.
What kinda price are you talking? If they are a REALLY good deal then go for it.
Old Apr 24, 2012 | 01:45 AM
G35SHAWN's Avatar
I had the same offset as well.
Old Apr 24, 2012 | 04:34 AM
daniel3ooo's Avatar
I'm picking them up for 1700 with tires..
G35shawn are those 8.5 fronts and 10.5 rears? They look good!
Old Apr 24, 2012 | 10:24 AM
gary c's Avatar
My Volk SF Winnings have the 8.5 & 10.5 with those offsets and they're correct for my coupe. I'm running 245X35s front and 275X35s rear which work perfectly.
Gary
Old Apr 24, 2012 | 06:31 PM
daniel3ooo's Avatar
^^ hey gary c..i looked at your pics on your garage and it lists 9.5fronts for your sf winnings? Just wonder if that was correct b/c the wheels look good on your car
Old Apr 24, 2012 | 10:27 PM
G35SHAWN's Avatar
They might be, i did sold those to a member here.
Old Apr 25, 2012 | 05:36 PM
VMRWheels's Avatar
Gary
+1
Should work just fine.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
TNRocker
Sep 21, 2015 08:36 AM
