Is there excssive tire wear on a lowered G?
Hey all, Im a noob so bare with me. When you lower a g coupe, is there excessive tire wear/camber wear? I only ask because Im thinking of getting 19's and 19 inch tires are not cheap. Im not one of the people that want 15 inch wide wheels or lots of camber, I like my car to be as functional as possible so I would like to get a lot of mileage out of my tires.
I'm running the SPL front camber kit and Stillen rear, couldn't be happier. As mentioned stay away from Ichiba anything and if you need positive camber adjustment up front, your only real choices are the SPC and SPL. Any other front kit is worthless.............
Negative camber by itself won't really mess up your tires that badly, if you're attentive to your setup. Make sure your toe settings are within spec, and be mindful of your tire wear. The style in which you drive will also have a large part in how quickly they wear out.
FS[Canada]: 19" Rays Volk LE37 Wheels Rims with Falken Tires
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
