ordered ADR 19" wheels, 9.5 in rear w/ 35mm offset... question about rubbing
Jan 11, 2005 | 09:35 AM
hey guys, i orderd a set of ADRs , in 19" for my coupe.. on stock suspension... rear wheel is 35 mm offset...
i want to put 285 30 19 on there... will i have any rubbing issues on stock suspension ? thanks guys
Reply 0
Jan 11, 2005 | 10:24 AM
You should be fine, thats a fairly conservative offset.
Reply 0
Jan 11, 2005 | 12:23 PM
actually that's a REALLY conservative offset for the coupe - I've seen these wheels many times before on G's and Z's and they need a 10mm-15mm spacer to look perfect (on the front and rear)... The 285/30 will be fine if you're going to match it with a 245/35 front (although you do not maintain the correct stagger for the setup)
Reply 0
Jan 12, 2005 | 04:47 AM
Post pics when you get them!
Reply 0
Jan 12, 2005 | 06:33 AM
isnt a 285 tire a bit wide for 9.5" rears?
Reply 0
