need help guys PIAA Superrozza
Old Aug 12, 2012 | 10:43 PM
G35-31's Avatar
so i bought these's with tires for 500 bucks. there 20x10 r and 20x8.5 f wanted to put them on my g35 which i saw it says 5- 114.3 on one spoke and i tried to fit them it didnt line up . i checked the other spokes and one said 5-120 can these be redrilled to 5x114.3?
heres some pics
Old Aug 13, 2012 | 02:31 AM
4DGS's Avatar
So one pair says 5x114.3 and one pair says 5x120?
These can't really be redrilled easily.
Old Aug 13, 2012 | 05:36 AM
G35-31's Avatar
no see thats whats crazy , they says both patterns on each wheel
Old Aug 13, 2012 | 01:11 PM
4DGS's Avatar
Are the studs lining up and just not fitting through the holes?
Old Aug 13, 2012 | 01:15 PM
G35-31's Avatar
no the studs are off 3 fit more then less but 2 dont there half showing in the holes
Old Aug 13, 2012 | 01:58 PM
VMRWheels's Avatar
I believe the wheels are 5x120. A lot of wheels display various markings like this, and what I've heard is that the smaller bolt pattern basically indicates the smallest PCD that it could be drilled to by the manufacturer, in accordance to the center area. For instance, if the center cap area was smaller it may go down as far as 5x100.
Either way, if none of the holes are lining up the only option you have would be to run adapters or to redrill them. I don't see a reason why these couldn't be redrilled though.
Old Aug 13, 2012 | 02:00 PM
4DGS's Avatar
They're a bitch to redrill as they are hard to plug or sleeve. Being a very open face with round spokes that flow into the lug holes makes them kinda sketchy.
Either way, you're looking at at least $200 to get them drilled. For what the wheels are worth resale wise... sell em to a BMW owner and buy some wheels with the right PCD.
Old Aug 13, 2012 | 02:02 PM
JaE35's Avatar
Moderator
G35 Sedan
Buy some spacer adapters, sick *** deal lol...
Old Aug 13, 2012 | 02:13 PM
4DGS's Avatar
$500 in Adapters...
Old Aug 13, 2012 | 02:29 PM
G35-31's Avatar
what you guys think i could get for them resale wise?
Old Aug 13, 2012 | 02:38 PM
VMRWheels's Avatar
Given the amount of money/time it would take to properly run those, I too would suggest possibly just selling them to a 5x120 car owner.
Old Aug 13, 2012 | 02:41 PM
G35-31's Avatar
now to find the 5x120 buyer lol
Old Aug 13, 2012 | 02:52 PM
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by 4DGS
$500 in Adapters...
there were a set of 4 adapters on craigslist for 120 out here in my area
Old Aug 13, 2012 | 03:00 PM
ca18detgabby's Avatar
might want to take them to a tire shop and confirm what bolt pattern they are so you don't have to deal with someone who doesn't know later on being pissed.
for the price, I would locate some adapters (can be had locally new for ~200 a pair or used for far less) and use them till the tires are dead. Then resell them.
what is the offset?
Old Aug 13, 2012 | 03:01 PM
G35-31's Avatar
25 all around offsets
