It's that time of the year again. Tires???
Old Jan 7, 2013 | 08:36 PM
JOHNNY CASH's Avatar
Hey guys! Please, don't beat up the noob here! Iv'e searched the forum already. I need new tires because I'm running on bald tires.
I need suggestions on some new tires that will last longer than the current setup. Maybe, bigger? wider? I'm tired of spending 1k on tires that don't last me a year. Money is really tight for me these days with kids milking every last penny.
I have a D.D. 04 G35 coupe with brembos. I'm currently lowered with a setup of 245/35 R19 and 275/35 R19 with spacer. Which I'll be getting rid of soon. Is there anything bigger than this setup?
Help, please!
Thanks
Old Jan 8, 2013 | 12:52 PM
VMRWheels's Avatar
I think the bigger issue is why your tires aren't lasting you a year. Sounds like more of an alignment issue than a tire issue.
Old Jan 8, 2013 | 05:57 PM
Yeah, I think alignment is one of the biggest problem for my tires. Every time I switch out the old tires, I noticed most of the damage happens with inner tire wear. When I lowered the G, I bought cambers for the front and rear to help alleviate the wear.
Is there any bigger size tires that will last longer? Even with adding mileage. I'm thinking about going back to OEM.
Old Jan 8, 2013 | 06:25 PM
VMRWheels's Avatar
Going wider won't make the tires last longer. Get an alignment and make sure your toe specs are in check. It just sounds like you have a bad alignment.
Old Jan 8, 2013 | 08:03 PM
phatgoose's Avatar
Try Continental DWS Extreme Contacts, they're rated for 50,000 miles. I used to go through soft tires every 10 months to a year, like Yokohamas,Kumho Ecstas and Dunlop Direzzas. I've had the Conti's on for 3 years now and 30k on them and still going strong. They cost about the same as other tires, about $1k. What tires are you running now?
Old Jan 8, 2013 | 08:07 PM
phatgoose's Avatar
well as long as your alignments been worked out......
Old Jan 8, 2013 | 08:10 PM
herrschaft's Avatar
Since your worried about the cost, going wider wouldn't make sense. Go with a harder compound tire and fix your alignment.
Old Jan 8, 2013 | 08:18 PM
phatgoose's Avatar
When buying tires check the UTQG rating...the lower the number the softer the compound = more grip shorter tread life. ....the higher the number the harder the compound = not as much grip but longer tread life. If your G is a daily driver, you won't need super sticky tires. All weather tires should do you just fine.
Old Jan 8, 2013 | 11:29 PM
RCL's Avatar
RCL
Get your alignment dialed in and as long as you're not slammed then tires should last you a good while.
Old Jan 9, 2013 | 03:55 AM
Thanks for the input.
Im running Falken 452.
Old Jan 9, 2013 | 02:49 PM
VMRWheels's Avatar
If your tires still have tread, flip them to the opposite side of the car and get that alignment.
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
