tire size help needed
Old Jan 8, 2013 | 11:52 PM
michael454rs's Avatar
hey guys i just picked up a set a set of coupe 18 polished the 7 spoke wheel and i need some recomendations on what size tire to run. they will be going on my 05 sedan. i wanted to run a square set up not staggered. i dont want rubbing issues, im on stock suspension and no plans of lowering any time soon. i was thinking of 235/40/18 but then again im a newb lol thanks for the help
Old Jan 8, 2013 | 11:56 PM
ohh by the way there 18x8 30 offset. looking for a while that looks good lol
Old Jan 9, 2013 | 03:21 AM
JDMswagSerf's Avatar
hmm. I'd go with a higher profile tire. middle number of tire size. (40)
that Is a low profile and you will feel the road more than you may want too. maybe 50 is best.
also a wider tire means more rolling resistance which means less mpg.
Old Jan 9, 2013 | 07:53 AM
6mtg's Avatar
235/40 is a good size I think 235/50 will look horrible I run 275 40 square and my ride is pretty nice before I switched to 275 I ran 245 40 square and I was lowered on springs an never rubbed or had any issues I also had the 18in 7 spoke
Old Jan 9, 2013 | 01:24 PM
So 235/40 would look good? Any else that run this wheel on there sedan ?
Old Jan 10, 2013 | 10:59 PM
i was using a wheel and tire calculator and 235/45 would almost be identical in circumfrance with almost no speedo error. anyone with a sedan running this rim on here?
Old Jan 11, 2013 | 03:09 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
I would use either 235/45-18 or 245/45-18.
Old Jan 11, 2013 | 08:34 PM
thanks for the help i think ill go with a 235/45 i think 245 would to wide i dont whant to have any rubbing going on
Old Jan 14, 2013 | 04:49 PM
VMRWheels's Avatar
Old Jan 17, 2013 | 10:38 PM
gary c's Avatar
Perfect size for your 18X8" rims and -30 offset, 245/40X18. You'll have plenty of traction and you're sedan should handle very well. Only buy tires with a UTQG between 300 and 400 no higher....Gary
Old Jan 17, 2013 | 10:47 PM
dominate's Avatar
Get 235/45 - ur speedo will have 0 changes.
Old Jan 17, 2013 | 10:56 PM
yeah i settled on the 235/45, looking at some hankooks v4 anyone have any input on this tire?
Old Jan 18, 2013 | 09:39 PM
gary c's Avatar
Michael, checkout the Tire Rack and ask them what tires they recommend....you'd still have a better ride without speedometer error with the 245/45s!
Gary
Old Jan 20, 2013 | 06:26 AM
DMC89692's Avatar
I run 245/40r18 on my 06 sedan. Speedo does read a little fast though, almost a 10% error according to the radar road signs. Although the signs may be incorrect too.
Old Jan 20, 2013 | 07:23 PM
4DGS's Avatar
Think you meant + Gary!
UTQG is actually pretty silly now, no two companies use the same method to measure tread wear. So the tread wear ratings only work inside of one manufacture of tire. For instance Bridgestone's TW of 300 could be the same as BFGs TW of 340.
It's stupid I know, but they have no way to regulate it.
marsman328
Northern California
Aug 11, 2015 07:29 PM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
