Larger tire setup, will lowering be an issue?
Old Mar 15, 2013 | 12:08 AM
MrBall0u's Avatar
So I just purchased a new wheel tire setup, found a GREAT deal on craigslist on couldn't resist. The wheels are 19x8.5 and 19x9.5 along with 255/45r19's
This setup is 18mm larger in total circumference than stock. I don't see this being a problem with anything but VDC and mph readings but that's not why I'm here. I have 350z eibach sportlines arriving tomorrow that will lower the car 1.7 inches total.
Will the new setup fit Inside the wheel wells without any issues? I'll be rolling the fenders and grabbing some spacers for a better look as well
Old Mar 15, 2013 | 12:32 AM
gary c's Avatar
You post questions but you didn't give us enough information! What do you drive coupe or sedan? What are the offsets, that's very important if you're driving around with more than two doors? A little more info you have your answers....Gary
Old Mar 15, 2013 | 12:44 AM
MrBall0u's Avatar
Agreed! I drive an 03 coupe with brembos
The offsets on the wheels are very weak I know but I'll bring em out a bit after with spacers
ARK design r8 wheels with Pirelli Pzero's
Front - 19x8.5 +45mm 255/45r19
Rear - 19x9.5 +25mm 255/45r19
Space from tire now to lowest point on suspension is 1.5 inches away and space from tire to inner wheel well is more than 3 inches.
If all goes well ill probably run 30-35mm spacers up front and 20~mm in back ... I'm not sure yet I'll have to measure once they get mounted and the fenders are rolled...
Old Mar 15, 2013 | 12:56 AM
gary c's Avatar
You only have one issue with your wheels Mr. B you'll need spacers in front, that offset is terrible! Don't try any fast corners until you do get spacers!! When you need to buy tires next go with 40 or 35 series the 45s are too tall. What are you going to do with your alignment once you've installed those springs? There's no doubt with Ebach springs you'll need a complete camber kit! SEARCH lowering or camber kits, all your questions have been answered....Gary
Old Mar 15, 2013 | 01:01 AM
MrBall0u's Avatar
Thanks for the help man! I appreciate it. I'm probably gonna wait to install the springs until I acquire a camber kit to keep things in check and my tires with tread. I'll def be lowering the sidewall to 40/35 next Time around but $600 for everything was too good to pass up. With the taller tires it should give it a nice racecar look when lowered especially with the GIGANTIC spacers I'll need lol
Old Mar 16, 2013 | 02:28 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
You'll run into VDC issues if you use the same size tire all around. That size seems quite large in overall diamter also. I'd scrap the tires.
Old Mar 16, 2013 | 02:54 PM
6mtg's Avatar
I run a 275/40r18 on all 4 corners and i dont have any issues with my traction control
Old Mar 16, 2013 | 06:45 PM
MrBall0u's Avatar
The size is just 18mm larger all around (.7 inches) . There should be no clearance issues and 275/40r18 is a pretty big tire, to have that on with no traction issues makes me a little more comfortable. Now, if these were to affect VDC how would they do so? Whenever the g is driven hard VDC is off.
Old Mar 16, 2013 | 06:48 PM
6mtg's Avatar
No no issues at all and i drive mine hard all the time
Old Mar 16, 2013 | 06:58 PM
MrBall0u's Avatar
Specification Sidewall Radius Diameter Circumference Revs/Mile
255/45-19 4.5in 14.0in 28.0in 88.1in 719
275/40-18 4.3in 13.3in 26.7in 83.8in 756
Just looked it up and mine are still a bit bigger.
For some reason that information doesn't seem right though
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
itschuckster
Jul 25, 2015 08:07 AM
