Burned through new tires in 1 month
If you had an alignment right tire pressure good struts and didn't do figure 8 burn outs then your tires shouldn't of worn like that . Even with the negative camber these cars come with .. That's why I was asking if your car has ever been in a wreck ? Even so the person who did the alignment could of just threw it out of wack if he didn't know what he was doing or the machine wasn't calibrated properly . Just my opinion .
Given that the OP said he put 2k miles on those tires during that month, it is a virtual impossibility to do that much damage to the tires that fast. Where is one of our HellaFlush guys? If anyone would have insight to how fast they burn through tires it would be some of them. I personally can't fathom that much damage in such a short time without visibly being able to look at the car and see that something was horribly off on the alignment.
The reason why I keep asking if he's been in a wreck is the fact that no matter how many alignments you do the car will never line up and some will dog track causing bad wear ....
Fireman07603
Aug 9, 2015 06:00 PM
