Hi All,
A month and a half ago i had the following installed by a shop: Coil overs, spc camber kit, new tires. My mechanic had the tires mounted and balanced and supposedly they did 4 wheel alignment.
Now all the tread on my rear tires have no tread. My mechanic swears that its most likely the guys who did the alignment but he took it back to them and they found nothing wrong.
Does anyone have another ideas how i ran through my tires so fast?
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
How is this possible, lol.. Do u check your air pressure regularly?? Do a lot of burn outs?? U check all your bushings and such??
ItsA..Gthing
close
- Join DateNov 2012
- LocationN.C
iTrader Positive Feedback100
iTrader Feedback Score(13)
Liked:218 Times in 187 Posts
Toe was out of wack..How low are you?
The air pressure in the tires is fine, I haven't done any burn outs and i haven't checked any bushings =/
I'm not very low at all probably about 6 inches off the ground but i'm not sure. i'll measure later
What tires did you get installed? This is hard to believe that you those tires are THAT worn out in one month.
herrschaft
close
- Join DateJul 2009
- LocationCoast
iTrader Feedback Score(18)
Liked:771 Times in 605 Posts
Do you have the alignment print out?
Hankook Ventus V12 evo K110 XL
I had the same tires on for two years with negative camber so i was surprised that these tires wore after a month.
No... the shop my mechanic went too doesn't give out print outs...
fyi the shop that did my alignment is Bridges Tire & Wheel Service
http://www.yelp.com/biz/bridges-tire...ice-burlingame
BowWizzel
close
- Join DateApr 2012
- LocationSan Jose
iTrader Feedback Score(10)
Liked:96 Times in 85 Posts
Id cause hell up in the shop but first try it politely. New tires like that in 1 month, somebody did not do there job right.
Are the tires cupped at all? If so, I would lean towards toe. If not, I would lean towards camber.
