WTF happened to my tire ?
Old May 19, 2013 | 03:25 PM
chaznad's Avatar
I had a 6hr drive yesterday ( 3hr each way ) and an hr into the drive i noticed my car shaking a bit and the tpms light came on , kept driving ... then on the way back ( 2hrs from home) it got really bad so i went out to check pressure and nuts tight and i didnt see anything. then today i pull all the tires and find the front passenger looking like this ...
4 days ago I stripped a stud on that wheel so i was running on 4 lug nuts , could that have caused the problem?
Im replacing the stud as we speak, but is this tire done for , i let the air out and it seems better shape wise
Old May 19, 2013 | 03:30 PM
ohfive's Avatar
Wow never ever seen that lol. I really doubt the four lugs had anything to do with that. My guess is probably a defective tire.
Old May 19, 2013 | 04:21 PM
xXHotelCrazyXx's Avatar
Broken belt/cord
Old May 19, 2013 | 04:41 PM
superchargedg's Avatar
^^^yep
Old May 19, 2013 | 05:27 PM
Knightstiq's Avatar
That tire has trouble written all over it. Get a new one first thing.
Old May 19, 2013 | 11:44 PM
zjohnson1's Avatar
Originally Posted by xXHotelCrazyXx
Broken belt/cord
+1
ie. tire is toast, need a new one... Don't drive on it
Old May 22, 2013 | 02:54 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yup, broken beltville.
Old May 23, 2013 | 11:10 PM
SoloScott's Avatar
I did that same thing on one of my old Civics. What causes that to happen? Is it just random or is this something that I/we can prevent?
Old May 24, 2013 | 09:12 AM
LoSt180's Avatar
Hitting a pothole can cause that, similar to a bulge on the sideway of a tire, or it could simply be a defective tire. If it has a warranty, I'd try that. Most good tire shops can easily tell the difference between a road hazard issue (pot hole) or a defective tire.
Old May 24, 2013 | 09:27 AM
gary c's Avatar
Broken belt/cord
Exactly....^....that's a defective tire and should be replaced under warranty. Are you running the recommended pressure in your tires? Tire shops may see broken belts frequently but I've only seen this twice....Gary
Old May 25, 2013 | 07:32 PM
Ghambino's Avatar
Freaky! I'd never use that tire again.
Old May 25, 2013 | 07:44 PM
chaznad's Avatar
I just went and got a new one , ya gary , running 40PSI which should be fine since the tires max is 49
Old May 29, 2013 | 11:30 PM
gary c's Avatar
This too is a problem....^....you shouldn't pay any attention to what the max psi on your tires are! We're supposed to run 35 psi in our tires, running 40 on a hot day and as far as you drove could be the reason this tire failed. Tire gauges for the most part aren't accurate, maybe you were really running 43 psi. Add a hot day on a long road trip you may have been close to maximum. Hit a few pot holes and you've wasted that tire. Run 35 psi, you'll enjoy driving your G much better and your tires will wear even!
Gary
Old May 30, 2013 | 07:24 PM
saywat?'s Avatar
no no to 40 psi man. i usually do 35 back 36-7 front
baker2795
Sep 2, 2015 06:00 PM
Frostbite91
Aug 20, 2015 07:20 PM
Ray Feta
Aug 13, 2015 11:40 PM
JMSABO
Aug 4, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
