Help on Tire sizes
Hello, first time posting a thread. I've found a deal on Varrstoen es111, 18X10.5 +15. The rims are not staggered so they are this size all around. My concern is whether or not they will fit on my 2004 Infiniti g35 coupe 5AT (no brembo package). I don't what to have to roll my fenders or anything. Will they fit? If so, what tire sizes should i use?
if you want you could stagger the tires even if the rims aren't. you could do 245-40-18 in the front and 275-35-18 in the back. that would keep you fairly close to stock roll diameters. or if you want you could probably do 275's all around. depending what your suspension set up is like and how low your car is.
My car is not lowered (as far as i know) it is completely stock. A local shop told me that they have done the same sizes to a g35 before but other tire shops such as kaltire are telling me that i might have to roll the fender, they said they're not sure if the rims will fit?
you won't have any problem with them fitting if your car isn't lowered. you could run either of those tire size options and not have a problem. it may look a bit funny with the wheel gap you're going to have, but no rubbing should happen.
