Non Staggered Setup, VDC issue?
Old Aug 21, 2013 | 01:51 AM
likwitcruz00's Avatar
Hi everyone,
I am trying to get a non staggered setup to be able to rotate tires. The G35 will just be a daily driver and nothing more. I currently have the 19 inch ray forged rims
Offset: +30mm
Weight: 19 lbs
Tire: 225/40-19
Rear
Offset: +33mm
Weight: 21 lbs
Tire: 245/40-19
I just got a set of rims with these specs,
Front & Rear
WHEELS SIZE: 19X8.5
BOLT PATTERN: 5X114.3
OFFSET: 35
HUB BORE: 73.1MM
WHEELS LIP SIZE: 2 INCH
I want to buy tires for all 4 corners
225-40-19
Will these tire setup affect the VDC and make it go crazy?
I tried to figure out the tire calculator, but still getting confused about the 3% rule
Thanks guys in advance
Old Aug 21, 2013 | 07:04 AM
Blue Dream's Avatar
I drove ttrank's car solo
The 3% rule is simple. Keep the rolling diameter between the front and rear tires lass than 3% of each other and the VDC will be happy. So, since you suggested all the same size tires you'll be fine. However, at +35 your wheels are going to be very sunken in and 225's all around are pretty skinny for the G so I would recommend 245/40/19 all around for more tread to be planted on the ground.
Old Aug 21, 2013 | 07:09 AM
Eno's Avatar
Eno
I'm certainly no magician but it looks okay- what I'd be more concerned about generally would be having a larger (taller) setup on the front than the back. It's the diameter (I believe) that throws the VDC- if it gets outside of certain parameters.
You'd have some concern if you were going to be taller in the front than the rear... I know from experience this causes problems.
I was just typing the same thing- for a coupe... Isn't it a bit more friendly to a Sedan or are the offsets similar?
Old Aug 21, 2013 | 11:02 AM
Thanks guys for the reply. Will the 245 40 19 in the front rub at all with stock fenders, or would it have to be rolled? Also when I get the 245 40 19 setup, would I need to remove a pin in the fronts to rotate tires; or is that only for the stock wheels.
Thanks again for helping me out with my newb questions
Old Aug 21, 2013 | 01:16 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
225/40-19 and 245/40-19 shouldn't cause any issues.
Old Sep 5, 2013 | 09:20 PM
guillaume_pom's Avatar
I run 245/40r18 tire on 18x9,5 +15 wheels and I don't have any issue with vdc and abs
Old Sep 6, 2013 | 11:20 PM
jomamahama's Avatar
don't do 225s bro, the front pushes hard as is. Steering is heavier with 245 but it won't push as much
Old Oct 3, 2013 | 08:04 PM
releasedtruth's Avatar
I rolled non-staggered on M45 wheels 245 40 19 for several years with spacers. Never a problem with VDC and even rotated them regularly.
Old Oct 25, 2013 | 01:44 AM
Thanks everyone for all the responses. I recently lowered my car with G35 eibach sportlines. Will having 245 40 19 rub my front fenders with 19x8.5 , with an offset 35?
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
