18" rim - next larger tire sizes
Old Feb 10, 2005 | 05:45 PM
uclabruins's Avatar
Hello everyone,
I did a search, but didn't find the answer.
I was wondering what the next 2 size(s) tires that a 6mt coupe could handle larger than the standard tires on the 18" rims.
Stock are:
225 45 18 (F)
245 45 18 (R)
With the next size(s), which one would you need to buy wider 18" rims?
Thanks.
Old Feb 10, 2005 | 05:49 PM
avs007's Avatar
Originally Posted by uclabruins
Hello everyone,
Stock are:
225 45 18 (F)
245 45 18 (R)
Thanks.
You can run a 245/40-18 on the front, with the stock rims. I don't know of anyone that runs anything bigger than that on the front.
The backs can get dicey. I know some people are running 255/40-18 on the stock rims, but those are slightly smaller in overall rolling circumference than stock. 275/40-18 is closest to stock, but you need at least a 9" wide rim for that. (9.5" is optimum for that size tire)
Old Feb 10, 2005 | 07:36 PM
kenchan's Avatar
Are you just trying to get a wider tire look? If so, just get the stock size in
the GS-D3's or S03's. they come out about 20mm wider than their widths.
The pilots are narrow tires.
Old Feb 16, 2005 | 07:43 PM
uclabruins's Avatar
I would like to get 18" rims with the largest tire (front and back) possible, so I would like to know what size rims I would need. Thanks.
Old Feb 16, 2005 | 09:53 PM
WolfsterX's Avatar
What is the STOCK offset? or otherway of saying Standard offset? Original offset? For the COUPE.
Old Feb 16, 2005 | 10:10 PM
biscotti's Avatar
Stock offset is +30mm.
Old Feb 16, 2005 | 10:22 PM
lowrider's Avatar
You can run 245/40/18 in front and 255/45/18 in back. You'll keep the stagger, reduce the understeer, and have a better handling automobile.
Lou
Old Feb 17, 2005 | 11:55 AM
Gsedan35's Avatar
Lou
I was hoping you'd reply Lou
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
