TPMS question
Old Jun 30, 2014 | 10:05 AM
e_nigma's Avatar
TPMS question
Quick question for the board... I've noticed the low tire pressure light go off on my coupe after about 10 miles of normal driving although when I check the tire pressure it's fine.
Is this normal or do you think I have a faulty sensor?
Old Jun 30, 2014 | 10:30 AM
PhoenixG35's Avatar
if warning light stays flashing, it's your tire. if warning light flashes at start, and goes solid and stays solid, it's bad sensor.
Old Jun 30, 2014 | 10:46 AM
e_nigma's Avatar
Thx... The light doesn't flash it's a solid yellow but doesn't come in immediately at start. It's usually after driving for a bit. Once the car is turned off for and restarted the warning light goes away.
Is there an easy way to identify/isolate the potential bad sensor?
Old Jun 30, 2014 | 02:19 PM
Urbanengineer's Avatar
Do the TPMS diagnostic mode check WITHOUT Consult 2. It will blink sort of like a morse code...
Slow blinks are _
Fast blinks are -
So:
_ _ - - - -
Is 24.
_ - - is 12.
Old Jun 30, 2014 | 02:22 PM
Post your sequence here, we can use the factory service manual to let you know which one is bad.
Old Jun 30, 2014 | 02:30 PM
e_nigma's Avatar
@Urbanengineer Thx! I'm not immediately familiar with the TPMS diagnostic mode but I'm sure a quick Google will help out.
Old Jun 30, 2014 | 02:53 PM
You have it. Go to forums > tech area > DIY. FSM (factory service manual).
Old Jun 30, 2014 | 02:55 PM
e_nigma's Avatar
Ah OK cool. Thx!
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
