G37s Wheels question
Old Oct 27, 2014 | 07:19 PM
g35fnatic's Avatar
Im getting a set of g37s wheels for my 35 coupe, someone told me that regular 12 - 1.25 lugs wont fit them and I would have to get oem infiniti lugs to make them work. Is that true?
I also want wheel locks on them, I plan on literally getting 20 gorilla wheel locks:
Amazon.com: Gorilla Automotive 71631N Acorn Wheel Locks (12mm x 1.50 Thread Size) - Pack of 4: Automotive Amazon.com: Gorilla Automotive 71631N Acorn Wheel Locks (12mm x 1.50 Thread Size) - Pack of 4: Automotive
Would these fit 37 wheels? has anyone tried?
Old Oct 28, 2014 | 10:48 AM
Urbanengineer's Avatar
If the wheels are 5x114 then they should fit fine... That other measurement you mention is the lug sizes in diameter and thread pitch. Those relate to the type of lug nut you need! You want to get gorilla locks for the OEM wheel seat type though, which you are going to need to look up. 20 locks look good on the wheels...!
Old Nov 5, 2014 | 04:41 PM
VenomGT9's Avatar
I'm running the 37 wheels on my 35 with OEM lugs, work fine.
Why do you want 20 locks? Doesn't that seem a little superfluous?
Old Nov 5, 2014 | 04:47 PM
g35fnatic's Avatar
20 locks wouldnt even be enough tbh, i live in brooklyn. i see 37 wheels on bricks soooo much. its terrible out here
Old Nov 6, 2014 | 08:50 AM
VenomGT9's Avatar
Maybe drill a hole in each lug to put a padlock on each one?
Old May 10, 2015 | 05:14 PM
upallnight's Avatar
Although the thread patterns are the same, a G37 wheel needs to use the lug nuts from a G37. The G37 lugs nuts actually goes into the holes in the G37 rims whereas the G35 lug nuts does not go into the whole and the number of threads engaged by the G35 lug nuts are way less then if you use the lug nuts from a G37.
G37 lug nuts
G35 lug nuts
Old May 10, 2015 | 06:16 PM
gary c's Avatar
Twenty locks will help, an alarm that goes off when your car is moved makes it safer! An alarm is a good investment when you consider the cost of wheels/tires...Gary
Old May 10, 2015 | 09:47 PM
bluedevils95's Avatar
20 locks won't help. If anything it will slow them down and **** them off even more. I do hear tilt alarms work great. If your car gets jacked up the alarm will go off.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
