Nail in Tire ... Am I screwed?
Old May 9, 2015 | 08:47 PM
g35shane's Avatar
Hey guys, I ran over a nail today and just wanted some opinions on whether it can be patched and what the odds are that it may not have even punctured all the way through. Of course I literally just bought these tires 3 weeks ago!
Attached Thumbnails Nail in Tire ... Am I screwed?-20150509_142734_resized.jpg   Nail in Tire ... Am I screwed?-20150509_142751_resized.jpg   Nail in Tire ... Am I screwed?-20150509_142944_resized.jpg
Old May 9, 2015 | 09:00 PM
Urbanengineer's Avatar
It's a non tread area it shouldn't be an issue. Call your local tire shop and get s quote.
Old May 9, 2015 | 09:53 PM
Texasscout's Avatar
Pull that sucker out, it didn't even penetrate the tire. Your fine.
Old May 9, 2015 | 10:15 PM
ronnieballgame's Avatar
If it isn't leaking now, odds are that it won't leak when you pull it out (famous last words). If it does leak, you are probably hosed...shops will not patch side wall punctures, only those through the tread area.
Old May 9, 2015 | 11:52 PM
gary c's Avatar
I can't believe a member would post something like this, don't they have any automotive knowledge or common sense? Take it to a tire shop, they'll submerge in water and look for leaks. If it does leak they won't patch it in that area! You're not the first one this happened to, nor the last...sadly!
Gary
Old May 10, 2015 | 12:39 AM
bluedevils95's Avatar
Shouldnt be no more then 15 to fix it. I caught begged things then that in my tire. Everything can be patched up. Nothing to worry about
Old May 10, 2015 | 01:21 AM
ScraggleRock's Avatar
No one will patch a sidewall.
Old May 10, 2015 | 03:29 AM
Mr. Brooks's Avatar
I see you're wearing Falken PT-722 all season tires. How do you like them.
Old May 10, 2015 | 10:45 AM
JOKER's Avatar
CLUB MODERATOR
you can patch that your self, no biggie. Most tire shops will obviously not patch it, but you can still talk to one of the guys in the shop and he might do it for you.
Old May 10, 2015 | 05:01 PM
g35shane's Avatar
Gary
Just because I'm a member doesn't mean I know everything about cars! I just wanted some second opinions and you guys have provided a lot of help to me in the past. I did end up pulling it out today and don't think it's leaking so I believe I'm all good! I will probably take it to a shop tomorrow though just to double check.
Old May 10, 2015 | 05:03 PM
g35shane's Avatar
There the 2nd set I've bought so I'm happy with them! Reasonably priced and good traction.
Old May 10, 2015 | 10:07 PM
coffeysm's Avatar
Pull it out and spray it with some soapy water and look for air bubbles. No tire place will patch something on the sidewall though.
Old May 12, 2015 | 07:52 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
That's right where the tires tread cap is molded to its sidewall, so its a seam area. Usually the reason most shops wont repair a tire with damage there.
Old May 12, 2015 | 11:00 PM
JKL1031's Avatar
daahhnn almost missed it
bjo16
Aug 4, 2015 09:52 AM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
justgotg35
Jul 19, 2015 12:33 PM
