19x9.5 Square with 245/35/19
Old Jul 10, 2015 | 12:43 AM
DG2Door's Avatar
Before I get flamed, yes I have searched-for quite a while- and I haven't found this specific question asked.
Im planning on running a 19x9.5 all around with 245/35/19 tires, will this cause VDC issues or should I run a staggered tire size
Thank you
Old Jul 10, 2015 | 10:36 AM
danoman32's Avatar
Why would you think this would cause issues?
Old Jul 11, 2015 | 02:13 AM
DG2Door's Avatar
Well I know that you get unwanted vdc interruptions if your tires arent a certain ratio spec from each other so I just wanted to know if running a square setup with that tire size with cause issues with how the car determines when vdc engages
Old Jul 11, 2015 | 01:44 PM
herrschaft's Avatar
It will be fine
Old Jul 14, 2015 | 04:43 AM
bryanr's Avatar
35 is low profile, I'd do at least 40. You'll have fitment issues in the front with 245, they will rub if you lower it. I'd do 235/40/19 in front and 245/40/19 in the rear. You can still rotate the tires side to side
And you might want to do a 9" width in the front instead of 9.5.
What offsets are the wheels?
Old Jul 16, 2015 | 07:53 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Handful of threads on running square sizes and VDC issues out there.
Old Jul 17, 2015 | 03:57 PM
Driehl1020's Avatar
Max sizes
I am running 245 40 20 in front and 295 35 20 on a 20x9 and 20 x 10.5. No vdc issues at all!
KruZZe
Feb 27, 2023 05:04 PM
doublej32
19 Inch
Jan 28, 2016 08:42 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
the93owner
19 Inch
Sep 23, 2015 03:03 PM
