What tire size? Help a noob :/
Old Dec 5, 2015 | 07:50 AM
Time2findDaJuan's Avatar
Recently ordered some vip modulars vrc110 in size 20x9+20 front and 20x10.5+20 rear and also ordered airlift 3h kit, so my question is what would be the best tire size since I plan on being low with bags?
Yes I know i'll need fender work, getting my bags installed at fender defender so they'll do that to.
Thanks in advance for the help
Old Dec 5, 2015 | 07:58 AM
Jusseth's Avatar
Are you trying to go stretched on the tire fitment?
Old Dec 5, 2015 | 08:04 AM
Just want an aggressive look, don't want a massive stretch..
Maybe a small stretch or just a meaty set up...not really sure
Old Dec 5, 2015 | 11:27 AM
Jusseth's Avatar
Would help to know for sure.
20x9 (front) - 235 width (stretched); 245 (less streched); 255 (should sit about flush)
20x10.5 (rear) - 255 (stretched); 265 (less streched); 275 (should sit about flush)
wall thickness- 35 (thin, low pros); 40 (good meat); 45 (would be kind of thick)
Just my .02 of above.
Old Dec 8, 2015 | 05:13 PM
bchalks's Avatar
correct on the tire widths. However he will be running 20s so definitely not going with 40 series tires...
OP go with what was suggested but 35 series tires if you opt for the stretch look or 30 series if you want the meatier fitment.
I'm running 20x8.5 245/35 front and 20x10.5 285/30 rear and it is beefy
Old Dec 8, 2015 | 06:10 PM
VenomGT9's Avatar
I'd go 275/30 rear
Old Dec 10, 2015 | 07:55 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
We would normally go with a 245/30-20 and 275/30-20 combo on a coupe.
Old Dec 10, 2015 | 08:48 PM
saywat?'s Avatar
imo 245 and 275 stretch is perps.
Old Dec 11, 2015 | 05:00 AM
Conissah's Avatar
On my (19 inch) 9.5 fronts and 11 rears I'm running 245/35 and 275/35 respectively. Fronts are barely stretched and wall height is good. Rears have decent stretch and are way beefier than they look in the picture. Hope this helps
Front
Rear
Old Dec 11, 2015 | 06:20 AM
Lartytiejdke3's Avatar
Originally Posted by Conissah
On my (19 inch) 9.5 fronts and 11 rears I'm running 245/35 and 275/35 respectively. Fronts are barely stretched and wall height is good. Rears have decent stretch and are way beefier than they look in the picture. Hope this helps Front Rear
I have a 245 on a 9.5 too
Wish I went 265
Old Dec 11, 2015 | 08:57 AM
VenomGT9's Avatar
And now you're selling them, waste
vstring
Mar 29, 2016 06:59 PM
abstrakg35
Dec 15, 2015 07:18 PM
Foxtrot_01
Nov 13, 2015 07:25 AM
ddietz97
Nov 10, 2015 08:52 PM
mbolin5
Media Share
Nov 10, 2015 12:46 PM
