Will these work for awd
Old Feb 14, 2016 | 11:14 AM
m17davis's Avatar
Hey. I will but these right now if these will for for a g35x. Will the different tires throw off the system and cause unusual wear because of the awd?
Old Feb 14, 2016 | 01:47 PM
danoman32's Avatar
Diameter is the same so it should work. The width has no effect on the and system unless your stretching tires on the rim which may effect overall diameter.
Old Feb 14, 2016 | 04:03 PM
G2B35AGN's Avatar
Not the same circumference. Left column is the 225s; right column is the 245s
Diameter 662.6mm 678.6mm
Circumference 2081.6mm. 2131.9mm
Opinions vary on how much difference you can have front to back before you start to put stress on the transfer case and screw up the computer monitoring for VDC. There is at least one thread you can search for that discusses this. IIRC, the range was 1% to 3% that people were saying was OK. I'll let you do your own arithmetic.
Old Feb 14, 2016 | 06:48 PM
m17davis's Avatar
I don't understand. What does the different tore width have anything to do with circumference
Old Feb 14, 2016 | 07:05 PM
Lartytiejdke3's Avatar
Man, the gen coupe crowd is ricey as hell
Old Feb 14, 2016 | 08:28 PM
m17davis's Avatar
Here are the overall diameters.
225/40 26.09"
245/40 26.72"
The difference is. 63"
Is this close enough or no?
Old Feb 14, 2016 | 09:02 PM
G2B35AGN's Avatar
225/40 26.09"
245/40 26.72"
1% of the 225s is .2609
1% of the 245s is .2672
The difference is roughly 2.5%.
You will have to decide whether to risk it.
See this:
https://g35driver.com/forums/g35-sed...ml#post5897687
For another discussion:
http://www.myg37.com/forums/wheels-a...s-and-awd.html
Old Feb 16, 2016 | 08:46 AM
VenomGT9's Avatar
Keep it simple, same widths with the same tires...never have an issue
Old Feb 16, 2016 | 11:09 AM
yosip1115's Avatar
Not worth it, could potentially eat your transfer case for dinner if it makes it past lunch time...
Old Feb 16, 2016 | 12:36 PM
Urbanengineer's Avatar
Yeah they are getting as affordable as the G35 but with more Budget mods.
Old Feb 16, 2016 | 11:29 PM
Mr. Brooks's Avatar
The difference is. 63"....Thats what she said,
sales@aamcomp
Engine-Vendor
Jul 27, 2016 10:42 AM
bigc
19 Inch
Feb 23, 2016 11:55 AM
BlueBelleG35x
Feb 18, 2016 10:27 AM
Detailed Image
Feb 11, 2016 08:49 AM
restrada
Feb 2, 2016 09:19 AM
