Brake Maintenance
Old Mar 3, 2005 | 04:14 PM
BombRush's Avatar
Brake Maintenance
I have 13's Stoptech BBK. And I was wondering how often you have to switch ur pads, rotors, and brake fluids. Do they last longer than stock brake system? I am a daily driver with no track..
Old Mar 4, 2005 | 02:47 AM
dklau33's Avatar
With pads and rotors it all depends on your driving style. There is no set time line. The harder you work your brakes, the faster they will wear down. Brake pads and rotors are wear items. They have minimum thicknesses and should be checked every so often. Once they are close or at the minimum then you need to change them out. With brake fluid the maintenance guide on a premium schedule calls for it to be flushed every 30K miles or 24 months. But thats assuming your using the oem fluid or something equivalent. Use a higher performing brake fluid that is more hydroscopic like Motul RBF 600 and you will have to change it out more often.
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
BradMD_96
Oct 6, 2015 09:31 AM
alinero718
Sep 27, 2015 09:35 PM
vamarris
Sep 26, 2015 12:56 PM
