Wheel replacement, extra 1/2 wheel stud??
Old Nov 7, 2018 | 08:05 PM
g35kurt95's Avatar
G35 coupe sport tuned suspension 19'' wheel
Hello,
I purchased some wheels with winter tires to install on my g35 coupe sport tuned 19'' .
When I got the stock infiniti wheels off it looked like the bolt pattern for the new wheels was correct however there was an extra protruding threaded piece that was about 1/2 the length of the wheel studs which prevented me from mounting the new wheels. With my stock infiniti wheels this piece fits nicely in a valley between two of the lug nut holes that the wheel stud would go through?
Can anyone provide some info on this?
Thank you!!
Old Nov 7, 2018 | 08:36 PM
Urbanengineer's Avatar
Pictures please, but it sounds like you have wheel spacers.
Old Nov 8, 2018 | 10:36 AM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
I'm assuming your car had a factory staggered tire configuration. You can remove that extra "stud" (it should just unscrew). It was there to prevent wheels with the wider rear tires from being put on the front.
Old Nov 8, 2018 | 10:40 AM
Doh! Good point. My G came with that already removed
ramo
Jan 4, 2011 03:07 AM
rpm06g35
Intake & Exhaust
Oct 23, 2010 07:26 PM
Back2VQ
Jul 17, 2006 01:23 AM
SammyJL
May 14, 2003 11:13 PM
