HELP!! Wheel stud stripped.
Old Sep 6, 2003 | 08:36 PM
ramo's Avatar
hows it going guys. well today i put on my wheels, but the frst one was a b****!! i guess i stripped one of the wheels studs on the car. what can i do? please help. i have the other 4 on ther, that should be fine for now, but please help me if you can
<P ID="edit"><FONT class="small"><EM>Edited by wreck on 09/08/03 11:07 AM.</EM></FONT></P>
Old Sep 6, 2003 | 08:42 PM
bkchang79's Avatar
Re: HELP!! WHEEL STUD STRIPPED
Do you have a tap and die set? Are the threads mashed up? Is the lug nut screwed up as well? I never replaced the wheel stud on a g35 before, but on my cherokee I just hammered the stud out since it was pressed in to the hub assembly and bought a new one and pressed it back.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
Old Sep 7, 2003 | 12:51 AM
Premier's Avatar
Considering you stripped it, you're better off bringing your car to a tire and wheel shop to have them special order the item for you and install it. Your other option is to bring it to an Infiniti dealership and have them take care of it, but they'll charge you up the *** for something like this. Expect the stud to cost $35-$50...........it's the install that's gonna cost you.
Old Sep 7, 2003 | 09:20 AM
icings's Avatar
Many shops like Autozone or Pepboys may carry it. It may be the same size as the sedan or even the same as other Nissan products. Go check it out. It is fairly easy to install it yourself. Expect to pay less than $ 5 per piece.
Old Sep 7, 2003 | 10:17 AM
ramo's Avatar
do you know how to install this one?
Old Sep 8, 2003 | 10:26 AM
tonke73's Avatar
I tore off a stud in half on my last car. I had to take it to a muffler shop to have them press off the old stud and had them press on another one. Cost me about $45 bucks.
Old Jan 3, 2011 | 06:42 PM
allmtrracin's Avatar
the stud is 12mmx1.25. this is the normal size for almost all infiniti's. If you have a 12mmx1.25 die you can easily take care of this yourself. Just put the die on the bad stud with a little wd40 and work it on and off until it threads on easy.
Old Jan 3, 2011 | 06:50 PM
gary c's Avatar
Drop by Nissan and buy one, go home and take your wheel off bang the old one out with a sledge hammer and install the new one with a little WD40 and your lug nut and wrench. Last time I bought one it was $1.25 give or take a few cents....
Gary
Old Jan 3, 2011 | 07:00 PM
boz35coupe's Avatar
i did the same thing last summer,
go to advance or autozone and tell them you need a wheel stud it only cost like $12,
go home take off the wheel, caliper and rotor,
hammer out the old stud put new on in
use a nut to tighten it to the hub,
put everything back together it takes about an hr to do, good luck
*100th post i really need to stop just lurking around haha*
Old Jan 4, 2011 | 01:39 AM
BW350GTskyline's Avatar
I would not recommend you driving with only 4 studs because of the off balance forces that can occur...
Old Jan 4, 2011 | 02:00 AM
bluedevils95's Avatar
FOr the guys that beat me to it. Go to Auto Zone or Pep Boys and order one. If you have the money then you can pay the dealers to install it for you but it would be better to do it yourself. You'll get the better pride of working on your own car. Or you can pay someone that know how to do it. It should be easy though.
Old Jan 4, 2011 | 03:07 AM
Silencer_0's Avatar
This thread is from 2003 I'm sure he figured it out by now.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
si_driver
Jul 14, 2015 12:29 PM
