Question regarding Tein H.tech and rims.
Old Mar 9, 2005 | 04:35 PM
YG35's Avatar
hi guys ... i am trying to lower the G with the 19x9.5 (font) and 19x10.5 (rear) offset is 22 all around. with the Htech which .6 (font) and .3(rear) will it rub or hit the fender?? thanks
Old Mar 9, 2005 | 09:10 PM
twantrd's Avatar
It shouldn't. I have 19's and im planning to drop the car 1" all around. I saw pix of someone with the same setup and you have like 1" gap between wheels and fender.
-twantrd
Old Mar 9, 2005 | 11:15 PM
YG35's Avatar
roll fender ?
Old Mar 11, 2005 | 01:34 PM
G35Bama03's Avatar
twantrd,
Will you have to roll your fenders with 19's? What springs are you getting to lower your car?
-Alex
Old Mar 11, 2005 | 01:44 PM
Keith N's Avatar
Yg35 -
I would go with the H Techs for the 350Z - a little more drop with a firmer spring rate. Plus, no alignment / camber issues due to excess lowering.
Old Mar 11, 2005 | 11:08 PM
YG35's Avatar
Keith N
thanks and thanks for the PM.. nice of you
Old Mar 12, 2005 | 03:22 AM
SKY6mT's Avatar
how much the Htechs drop ? and really no alignment or camber issues with those ? i am planning on get 19 stms and want to lower my car for looks...
Old Mar 12, 2005 | 03:44 AM
NORCALSTI's Avatar
i put the 350z h techs on my g35 coupe on wed. from ground to fenderlip in front im at 26 1/8 and rear about 27 incches from ground to fenderlip.
not sure what the stock set up measured im on 225 45 18 and 245 45 18. oh btw im giong to cut the rear bumpstop top part down so i get another 1/2 inch drop should be perfect
Old Mar 12, 2005 | 04:01 AM
RaySur350GT's Avatar
With a +22 offset on a 10.5 rim and lowering you car. Make sure your tires are 275/35 or 275/30. That offset has 350Z rubbing on the rear fenders and I know it will have the G35 doing the same thing. Best to roll or shave your fenders to be safe.
Old Mar 12, 2005 | 04:57 PM
YG35's Avatar
i have 275 35 in the rear ..
and yeah i wanna know that if really no alignment or camber issues with those
Old Mar 12, 2005 | 05:07 PM
kenchan's Avatar
YG- you still need to get an aligment after the install....just more possibilities that
you will get it back to factory specs, that's all. good luck.
275/35/19's are perfect size.
Fire0nic3
Aug 31, 2015 03:18 PM
Jnm07
Aug 6, 2015 03:03 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
StephonW
Aug 5, 2015 12:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
