HP EVO Wheels
Old Mar 9, 2005 | 10:46 PM
anish3232's Avatar
HP EVO Wheels
Does anybody have a G with the Hp Evo wheels or could someone photoshop these wheels on a G sedan would be appreciated. I have a Silver G35 sedan and I was thinking about going wit 18x8 in the front and 18x9 in the back. These rims are very inexpensive the Staggered setup is a little less then 600 without tires.
Thanks
Any input on how they would look would be appreciated. Also has anyone herd of HP wheels and if they are good.
Old Mar 9, 2005 | 11:33 PM
j12baller's Avatar
those wheels arent that bad. do they have a website? how much do 19's staggered run?
Old Mar 10, 2005 | 12:02 AM
j12baller's Avatar
you got me thinking...
hmm....
19x9.5 and 19x8.5
what do you guys think?
Old Mar 10, 2005 | 12:24 AM
VinNYCG's Avatar
G SQUAD
check out pics of illg35's car. He has them in 19's on a desert plat. sedan. It looks pretty good.
-Vin
Old Mar 10, 2005 | 10:42 AM
g35sedamn's Avatar
i have the same wheels in 18x8 and 18x9 in dark silver. they are good for the price. they look nice. they are a little heavy but i dont usually track my car so im not to concerned. i have hit some so cal pot hole pretty hard and not dented them yet for being cast. the offsets are good. the rear is a bit agressive but mine's lowered on stechs and doesn't rub. sorry the car is so dirty in the pics and the quality of the pics is not great either.
Old Mar 11, 2005 | 02:20 AM
j12baller's Avatar
ok someone explain to me...why these wheels wouldn't fit on my car?
19x8.5 and 19x9.5...something about an offset...i don't get it
Old Mar 11, 2005 | 11:39 AM
g35sedamn's Avatar
j12baller, the wheels will fit on your car but if you look at them from the side they will not be flush with your wheelwells. they will be in towards the center of your car about an inch. if thats cool with you thats cool but the offsets are more towards a sedan than a coupe. coupes usually run about +22 in front on8.5" wheels. some run +17 with some camber. about the same in the rear with a 9.5 - 10" with a +22. the wheels will fit on the car none the less. ask someone in the coupe forum and see what they say. and they might not clear brembos with out spacers. just some things to think about.
Old Mar 11, 2005 | 02:33 PM
kenchan's Avatar
Im those that are tired of looking at coupes with its tires sticking out when
looking at it from the back. the +38mm offset (which I believe are for those HPs)
are ideal for me. The front might need a 5mm offset spacer to clear the brembo's.
the rear should clear no problem.
Old Mar 11, 2005 | 03:11 PM
j12baller's Avatar
i do not have brembos. i have an automatic.
Old Mar 11, 2005 | 08:22 PM
jjellyneck's Avatar
I saw a set on a silver sedan and was shocked at how good they looked. I'm still not sure about the weight--that will be strong factor in my decision to buy these. Anybody know the weights?
Old Mar 12, 2005 | 01:12 PM
kenchan's Avatar
probably somewhere near 27-28lbs. Those are dressup wheels, who cares
about weight as long as they look good... no?
Might want to look at toyo t1's for lightweight tires...at the end its the gross
weight.
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
cbax
Aug 17, 2015 07:41 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
