Tein S Tech cpe vs sdn
Old Mar 13, 2005 | 06:03 AM
twantrd's Avatar
Is there any difference between the Tein S Tech springs for the Sedan and Coupe? What happens if you put the sedan springs on the coupe? Any ideas. Just curious because I will be buying these springs and want to do a visual inspection to make sure that they are the coupe...unless it doesn't matter. If it does matter, does anybody have a picture comparison for the coupe vs sedan? Thanks.
-twantrd
Old Mar 13, 2005 | 12:20 PM
kenchan's Avatar
I thought they were the same kit.
Old Mar 13, 2005 | 04:06 PM
twantrd's Avatar
Yea, I was kind of wondering if they are the same kit. If so, then that's all I need to know. Thanks.
-twantrd
Old Mar 13, 2005 | 04:17 PM
NORCALSTI's Avatar
OK CHECK IT Out
i put the 350z tein h's on my g35 coupe earlier this week
now in front from ground to fenderlip its at 26 1/8 and rear its at about 27 inches from ground to fenderlip. so that will show you how much lower than stock it will put u. IF you can measure yours the way it is stock and post it here so we get a true measurment of final drop.
btw in rear im going to cut the bumpstop mounts down so i can get another 1/2 inch out of it
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
