Anyone here use 225/55/17's
Old May 17, 2003 | 04:27 AM
3point5SE_Auto's Avatar
These are only 1.6% off the original speedo but allow the use of bridgestone potenza s-03's which I like
Anyone?, How about 225/50/17's? (Nitto 450's)
Better Life thru Chemistry
Re: Anyone here use 225/55/17's
oops I forgot to say on stock 17x7 wheels
Old May 17, 2003 | 02:53 PM
Msedanman's Avatar
O.F. Administrator
235/50/17's would be just about perfect if they're available. Otherwise the difference in the 225's isn't worth worrrying about.
<font color=green>GSM</font color=green>
Old May 18, 2003 | 11:20 AM
235/50/17's are available, however the only decent tire out there is the Pilot Sport A/S, there are no good summer tires out there
Old May 18, 2003 | 11:49 AM
Gordgee's Avatar
Administrator
I saw one G sedan with 225/55-17s. Pilot Sport A/Ss I think, so I'm not sure why he went with those instead of the 235/50-17s. Should be fine though and within acceptable limits.
<font color=green>GG</font color=green>
Old May 18, 2003 | 01:48 PM
Gsedan35's Avatar
The stock GS-D's I was running stuck really good. But I'd take S-03's over the GS-D's any day, even if they were the same width. Going a smidge wider would be even better.
I do not support putting 235's on only 7" rims and neither do most of the tire makers. And running tires like that on a narrow rims does compromise performance, their's a reason for needing 8" vs 7".
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
clear corners
Old May 19, 2003 | 05:07 AM
ryoken's Avatar
On rim widths, you have to check the specs for a given tire at a given size. For instance, the Pilot Sport A/S at 235/50R17 recommends a 7.5" rim, but will fit comfortable on anything from 6.5" to 8.5". In this case, 7" isn't even the minimum recommended, so I'd say it's just fine.
Old May 20, 2003 | 10:01 AM
thanks y'all
BTW, I ran 235/50's on my 17x7 Altima stock rims for 22,000 miles but again 205.00/tire would kill me after a while. the S-03's are only 165.00 each or so. I really was looking for anyone who ran the 225/55's. BTW you can get Nitto 450's in 225/50 configuration (albeit V-Rated) for 110.00 each.
just some FYI for y'all
Old May 20, 2003 | 11:40 AM
ryoken's Avatar
225/55R17 and 225/50R17 are both close enough to stock to be okay. Your speedometer will be off by 1mph at 60. (You'll actually be going 61 with 55's, or 59 with 50's.)
I suppose a person who's really concerned with the odometer could alternate between the two. [img]/w3timages/icons/tongue.gif[/img]
Old May 20, 2003 | 01:16 PM
Gordgee's Avatar
Administrator
3point:
Why not try the Falken Ziex ZE-512, a V rated A/S performance tire? They were the one's I was going to try prior to going to the Pilots. Great feedback from those that have tried previous Falkens, and the Ziex is supposed to be better. Great prices on them too. Previous thread:
https://g35driver.com/forums/showfla...&sb=5&part=all
Old May 20, 2003 | 02:55 PM
I wanted a non A/S tire. I have a Jeep for the days it is raining, snowing or other wise bad.
anynigma
Sep 30, 2010 07:08 PM
ntoxtiger
Archived Sales
Nov 30, 2009 10:00 PM
infinitialex
Dec 14, 2006 09:22 PM
TheTrance
May 17, 2006 12:49 AM
