suspension advice please
Old Apr 2, 2005 | 01:25 AM
TINMAN's Avatar
trade cars? ok,i'll trade you my pinto
sound like those 2 are the way to go.unless somebody experienced problems with them before.heelllloooooo.....
Old Apr 6, 2005 | 09:52 PM
KORRUPT's Avatar
OK!I finally got the 350evo swaybars installed and the tokico shocks and the espelir active gt springs. First off the drop they report for the springs was dead on at .4 of an inch, at least on my ride.The springs feel great, not a real harsh difference in ride at all. The shocks really take care of the bumps and the tires feel like they are pasted to the road. The sway bars are set at med/med and the shocks are 4.5 turns from full stiff all around. Cornering is great, the car handles like a dream. I am completely happy with the setup except for one thing,the bushings seem to be making some noise.They were lubed well but perhaps not with the proper type of lube. Does anyone have any ideas which lube would work the best. I'll post some picks when it stops raining for two minutes.
Old Apr 7, 2005 | 09:02 PM
636Racer's Avatar
Silk Road coilovers.
They're similar to JIC, IMO more reliable than JIC.
www.silkroad-usa.com
the application is for the 350Z, but you can specify your spring rate to a softer spring rate vs the aggresive spring rates meant for the 350Z.
you can order them through www.munkywurks.com
or call they're shop at 808.848.8794, ask for sean or clint...tell either of them that chris with the twilight g35 referred you.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
Learned Hand
Oct 1, 2015 09:02 AM
